Frequency Shift when changing modes
David
David Member
edited March 2017 in SmartSDR for Windows
Listening to a signal on lower sideband and switch to upper sideband then switch back to lower sideband the signal now 50 cycles off frequency, but the vfo still reads the correct frequency. Move the vfo 50 cycles and station back on original frequency.
  • Tim - W4TME
    edited March 2017
    David, This is a previously reported issue. We intend to correct this issue in an upcoming release of SmartSDR.
  • Eric-KE5DTO
    edited February 2017
    I can confirm that this has been duplicated and fixed. You'll see it in the next release. Thanks for reporting this.
