Looking for USB Soundcard
Steve - K5FR
Does FRS have a recommendation for a decent USB sound card that will work for direct audio connection between the F6000 radios and digital applications?
SignaLink USB works great here. Supplied cables go right into mic and phones jacks, and you're on the way. 73 George/KF2T0
Steve, Please clarify what you mean by "direct connect". Any sound card is usable, you just need an analog interface between the radio's analog IO ports and the PC sound card, preferably isolated to prevent ground loops and RFI ingress. You can not connect a sound card to the USB port on the radio (of for that matter any device to the radio's USB port.0
I was referring to a physical connection rather than a software (VAC) connection. Something similar to the Signal Link George mentioned.0
Thanks for the clarification, Steve. You can cobble together an analog interface through the ACC port too.0
This discussion has been closed.
- 323 Community Topics
- 577 The Flea Market
- 7.7K Software
- 6.2K SmartSDR for Windows
- 386 SmartSDR for Mac
- 253 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 365 SmartSDR API
- 9K Radios and Accessories
- 125 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 848 Genius Products
- 437 Power Genius XL Amplifier
- 298 Tuner Genius XL
- 113 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 134 Contesting
- 701 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 924 Third-Party Software
