Start up feature request for SSDR
Request those with transceivers have the transmit windows automatically start when starting SSDR. I would imagine most people will transceivers will in fact want to transmit. For those who are only going to SWL they can close the transmit control window. Thanks Greg AB7R
Greg, When SmartSDR is started, Slice A is already designated as the transmit slice. Am I missing something here?0
What is it exactly you are seeing on startup? On mine, the slice that is at 14.100 has the TX focus, is it different for you?0
I believe Greg is talking about the transmit window where you can set power, adjust the equalizer, etc.0
Ah, if that is the case, that is referred to as the Transmit Control Panel. My assumption is that would fall under the radio persistence feature, where the radio comes up in the state it was in before it or SmartSDR were shut down. Greg - is that what you are referring to?0
I am sorry that I used the wrong terminology. I should have fired-up my 6700 to check for the correct name before I posted.0
No problem, Ed. That is why we established the community - to help, educate and inform.0
Thanks all. Yes, It is the transmit control panel I am referring to. FB if the status of that window is part of the persistence list. Thanks!! 73 Greg0
No problem Greg!0
- 375 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
