Start up feature request for SSDR
Greg
Greg Member ✭✭
edited September 2017 in New Ideas
Request those with transceivers have the transmit windows automatically start when starting SSDR. I would imagine most people will transceivers will in fact want to transmit. For those who are only going to SWL they can close the transmit control window. Thanks Greg AB7R
2 votes
Already Offered · Last Updated
  • Tim - W4TME
    edited March 2017
    Greg, When SmartSDR is started, Slice A is already designated as the transmit slice. Am I missing something here?
  • Neal_K3NC
    Neal_K3NC Member ✭✭
    edited August 2013
    What is it exactly you are seeing on startup? On mine, the slice that is at 14.100 has the TX focus, is it different for you?
  • Ed, K0KC
    Ed, K0KC Member ✭✭
    I believe Greg is talking about the transmit window where you can set power, adjust the equalizer, etc.
  • Tim - W4TME
    edited March 2017
    Ah, if that is the case, that is referred to as the Transmit Control Panel. My assumption is that would fall under the radio persistence feature, where the radio comes up in the state it was in before it or SmartSDR were shut down. Greg - is that what you are referring to?
  • Ed, K0KC
    Ed, K0KC Member ✭✭
    I am sorry that I used the wrong terminology. I should have fired-up my 6700 to check for the correct name before I posted.
  • Tim - W4TME
    edited December 2016
    No problem, Ed. That is why we established the community - to help, educate and inform.
  • Greg
    Greg Member ✭✭
    edited March 2017
    Thanks all. Yes, It is the transmit control panel I am referring to. FB if the status of that window is part of the persistence list. Thanks!! 73 Greg
  • Tim - W4TME
    No problem Greg!
