Mic cable construction and materials for the Aurora
Mike58
Mike58 Member ✭✭
I just completed building a microphone cable for the Aurora which I hope to see in the 4th Q. I will be using my Heil PR781 mic and purchased cable from Heil and went with Amphenol XLR and 3.5mm TRS plugs. Part numbers listed below. This should be compatible with the 6400,6600 and 8000 series radios as well. ( Tip,Ring,Shield)
Cable Heil HW20
Amphenol XLR connector AC3FB-AU
Amphenol 3.5mm TRS connector KS3PB-AU
Mike N9ZX
  • Frank Jim G. Mcfee
    hola mike me gustaria hacerte algunas preguntas sobre el cable he vistos algunos cables en amazon quiero saber si son los correctos atentamente frank hk0rmr mi correo es frank.gonzalez01@icloud.com te agradezco la ayuda
    Hi Mike, I'd like to ask you some questions about the cable. I've seen some cables on Amazon and I want to know if they're the right ones. Sincerely, Frank hk0rmr. My email is frank.gonzalez01@icloud.com. Thank you for your help.
