Seamless Integration of Outdoor Tuner
ChrisNia
I have a dual antenna coupler/tuner with the following I/O
+/- power supply
+12 volt signal wire to initiate tuning
+12 Volt signal wire from Coupler during tuning (Back to radio/it powers an led on control box while tuning is in progres)
+Antenna selector cable +12 volts = ANT 1 0V = ANT 2
+12 power source
I am using the Flex 8400 / PGXL / TGXL / Antenna Genius with Output module
Currently I have the output module switching power to tuner based upon band selection in the antenna genius table
Is there a way to program FLEX 8400 accessories port to send a tune command to coupler (+12V) if "TUNE" is selected in SMART SDR and inhibit transmit RF while +12 signal (In use) is being received from tuner?
Thank you
+/- power supply
+12 power source
Thank you
In furtherance to the previous post , I can confirm that the Antenna Coupler uses the same protocol and wiring as Kenwood and Icom outdoor tuners.
There:
Tune button
In Tuning LED indicator|
3 Position Switch for Antenna A or B
Setting switch to Middle grounds both antenna0 -
is this a commercial tuner or home brew? I love the construction.
It is made here locally in Greece by a professional Electrical engineer, it has excellent characteristics;
It uses the ICOM protocol.
1KW DUAL MEMORY AUTO ANTENNA COUPLER
- 1ΚW PEP (SSB) FOR 25 METER LONG ANTENNAS (1.6 - 30MHz)
- 50 MEMORIES IN EACH ANTENNA OUTPUT (“A” AND “B”)
- ANTENNA CHANGE WITHOUT RETUNING!
- "TUNED" START UP AT THE LAST USED FREQUENCY!
- MEMORY STORAGE WITHOUT USING BATTERIES!
- RECEIVING COMMANDS FROM ICOM , ALINCO AND KENWOOD
- 6pF OUTPUT CAPACITOR STEP!
- DIRECT CONNECTION OF A DIPOLE BETWEEN OUTPUTS "Α" - "Β"!
- GROUNDING OF NOT USED ANTENNA WHILE OPERATING THE OTHER!
- GROUNDING BOTH ANTENNAS WHEN 12V SUPPLY IS CUT!
- PROTECTION FROM STATIC DISCHARGE WHILE OPERATING!
Thank You. Very Nice!
- 391 Community Topics
- 664 The Flea Market
- 157 SmartSDR+
- 441 SmartSDR for Mac
- 275 SmartSDR for iOS
- 265 SmartSDR CAT
- 206 DAX
- 386 SmartSDR API
- 61 Aurora
- 299 FLEX-8000 Signature Series
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 471 Remote Operation (SmartLink)
- 144 Amateur Radio Interests
