FRStack and Elgato Stream Deck Pedal
I am trying to get FRStack and the Stream Deck Pedal to work with MOX. Currently, out of the box config, the Pedal will do MOX but only as a toggle between on and off. From the FRStack documentation, I think I want a HOLD instead of Toggle. What I dont see is how to do this via the api configuration of the stream deck pedal. Below is how it is currently configured.
But I dont see where to change toggle to hold. I did try with slicemaster and its stream deck profiles and it works fine. However, I do not want to have to run both frstack and slicemaster, I would rather just use frstack. Is there documentatioin on the api side of frstack?
TIA
Charles KQ4TNF
ok, I think I have figured it out. The toggle button is what is defined so that is what it is. What I think I need the the "state" button which has action when pressed and action when released.
I will test this out tonight and see how it goes
yes. You define the “on” state and “off” state with the FRStack commands for MOX on and off.
73 Dave wo2x
- 322 Shack Infrastructure
- 227 Networking
