Setting up Log4OM
AB7R
I have SC connected to WSJTX via TCP port 60000.
Now trying to connect to Log4OM which should be easy peasy. I created a new serial CAT port 14 for slice A. When I go to Log4OM I select Setting>hamlib and autostart. On the hamlib tab I tried both FlexRadio SmartSDR slice A (not connecting). and FlexRadio 6xxx (also not connecting). Serial connection is selected.
Should I be using the IP of the radio and port 4992 as a network connected radio??
What am I missing? Does smartcat work like com0com and create two com ports? 14 for ssdr and 114 for the logger? I tried both and still no luck.
Greg
I wonder if you may find this thread, my comments, and OmniRig to be helpful?
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
