Proper Transverter settings for the 6400M
VE3DZP
Howdy folks! I just received my 144/148 mhz transverter from the transverter store as well as a little RM LA 145 amp. In all the articles have found in the initial setup is keep the power to around 5 dbm in transverter setup panel on the Flex.
Ok that done the output was very low but I found turning the RF power on the front of the flex to say 20 gave 25 watts output from the amp.
Now my unsolved question is what or why does the RF power control the transverter output. I thought it was fixed in the setup menu, turning it up can it destroy the transverter?
Gary
Gary
Gary,
You should set up the drive power in the transverter setup form so that full power is delivered when the power slider is at 100%. That way you can never overdrive your transverter. Just connect a power meter between the transverter and a dummy load.
Mack
W4AX
Alpha Team0 -
Hallo and sorry for asking,
i have seen the video but i dont understand the information over RF configuration.
is it Common
or
is it Splitt RFPlease help, thanks
Hi Eli, if you want the same antenna for transmit and receive, then you want common RF.
If you want one antenna for transmit and a different antenna for receive, then you want split RF.
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
