Flex 6600 connection with Microham SM
Sergey KN7K
Member ✭✭✭
I did a little search here and it is not clear to me how to connect 6600 and Microham Statio Master. I use Microham microkeyer II and station master for a long time with Yaesu FT5000 and it works great. I am planning to retire microkeyer II but use SM for antenna switching. Besides USB connection to PC and choosing COM port, do I need any other connections to SM? Thanks Sergey, KN7K
Sergey this support probably should be directed to Microham. I notice they have a specific cat cable CAT RS232-YX that they advertise for use with the flex 6000 series. this may be a cable that you interface using the USB cat option of the flex. I would guess that the band data for the MH would come directly from the CAT USB interface of the flex.0
Thank you Chris,
I saw this cable mentioned here on community but I still do not understand how it can be used.
It seems like one side of this cable is 3.5mm CAT could be connected to a Station Master, but where another end of the cable DB9 is going?
Should I use DB9 to USB converter?
Sergey, KN7K0 -
You likely will need a genuine FTDI USB to Rs-232 converter to plug into the USB port in the back of your flex 6000 radio. You can find a guide for the usb cable interface in the documents section of flexradio.com, and the usb to ra232 can be purchased from flexradio store or if you know exactly what you are looking for you can get them at mouser0
Thanks Chris, it worked.
One cable connected to 6600 with FTDI chip recognized by radio and I renamed it to Station Master. Second cable connected to 3.5mm CAT port of Station Master and to FTDI cable.
Works as a charm.
Sergey, KN7K1 -
Great news Sergey, glad to hear it worked out OK. enjoy your fully integrated Flex 6600!0
hi Sergey
did you used 2 cables, or you manually converted the (usb - rs 232 cable with FTDI) to 3.5mm jack?
request your feedback as am stuck
Honestly, i do not remember how I made it work, i did not write it down.
Sorry...
Last year my SM "smoked" and died, I switched to Antenna Genius.
Sergey, kn7k0 -
thanks dear for your prompt response
Basil, 9K2RX
Hello,
today I got a FlexRadio 6600 and I would love to connect the Station Master to it. Any Switching diagram available or some further infos?
vy 73
DL1DMS0 -
You need to purchase or make the cable CAT RS232-YX that Microham sell https://www.microham.com/contents/en-us/d1213_CAT-Cables.html
Then buy a FTDI USB to RS-232 cable/adapter to plug in to the Flex and connect them up, that will give you CAT data from the Flex to the Station Master.
Rich
Hey Rich,
Thanks for your answer. The cable is already ordered.
Have a great day!
DL1DMS0
- 391 Community Topics
- 664 The Flea Market
- 157 SmartSDR+
- 441 SmartSDR for Mac
- 275 SmartSDR for iOS
- 265 SmartSDR CAT
- 206 DAX
- 386 SmartSDR API
- 60 Aurora
- 298 FLEX-8000 Signature Series
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 144 Amateur Radio Interests
