Flex 6600 Selected Antenna Indicator
WK1O
I am looking to get an external signal to control the switch to show selected RX antenna - ANT1, ANT2, RXA, RXB
The Hi-Z array is located physically very close to 4Sq on 160M and the 4 Sq needs to be detuned when RXA is selected by the radio.
Does anyone know how to get the get this info into the relay switch?
I see FRStack gets this info from Flex. The question is how to get this signal into one of the ports?
I am sure somebody solved this already. I just could not find it in the discussions.
Thank you much
Alex, WK1O
Hi Alex, you can use an external relay board (e.g. Denkovi) to switch on certain conditions. If RX Antenna, RX A or B is selected + frequency range or band set relay "active high" or "active low".
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
