6500 and RTTY
Hi all
Which RTTY program would you recommend to work with a 6500, using version 2.7.6 on a Win10 machine ?
Should be easy to install, and mostly used for DX chasing (split should be easy to set) and occasional contesting .
Any advice will be appreciated
7Thanks + 73
Paul F6EXV
Paul,
ici HRD digital master avec les deux vfo
73, on5po, Janny
It depends on what level of integration you want.
If you want to operate the RTTY software alone, any one can do the job. I know a lot of people are using fldigi.
If you want an integration with contest software like N1MM, the most suitable software are MMTTY, 2Tone or GRTTY.
Hello all
Thanks to all who replied. Will keep trying various programs, as there dopes not seam to be one that is outlined over the others.
Thanks + 73
Paul F6EXV
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
