Logger32 spots in SmartSDR
Hello.
I am looking for a tutorial/instructions/tips to configure Logger32 to send DX spots to SmartSDR for visualisation on the panadapter.
Thanks in advance.
Pete MM0TWX
Pete,
First, you need to enable the UDP broadcast of DX Spots from Logger32. To do this, right click on the Logger32 DX Spots pane and check the item "Enable UDP broadcast of DX Spots"
Second, you need to set up a port on SmartSDR CAT to receive the UDP spot broadcasts from Logger32. To do this, click "add a port" on SmartSDR CAT, select the "N1MMspot" port protocol and click "save". This will show the UDP port as 12061
Finally, enable Spots on SmartSDR by going to Settings>Spots.
Section 28 in the SmartSDR Software User Guide v2 covers the user controls
73 John
Thanks very much!
my logge32 has a UDP set to 2237
But using the default 12061 seems to work as well
Didier
F6DXE
Hmmm, it is not working on my Flex 6500 and Logger32 …..
Daniel
HB9DDS
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
