Transverter Repeater Function - Observations - SmartSDR v3.2.39
First.. although the category is Windows, IOS has the same findings...
Observation 1 - When setting up a repeater off-set and testing for access, there is no indication of the offset xmit frequency at key down. While the offset setting does work, this is not intuitive. (I do use memories for these repeaters, and they work well). Further, the expected indication of modulation on the panadapter, upon xmit, shows no carrier which by rights it should not, since the xmission is indeed offset.... Still not very intuitive.
Observation 2 - To compound the issue with number 1 (above), if I manually move, (drag to a new simple frequency) there is nothing to alert me that a repeater offset is still enabled !!! All is see on xmit is a lack of apparent audio for some reason... which, since I am remote to this flex/transverter, had me yanking hair for a while to find out why I had lost audio out. I have learned to program some simplex channels and always go to them after leaving repeater mode, rather then needing to OPT to turn off repeat/tone offset.
Maybe this will be of some help to those setting up flex/transverter combos
Barry K6ZA
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
