Amplifier To Boost Transverter Output Level
A mini-circuits GVA-63+ perhaps? I'm not sure how much DIY you are willing to tackle here...
@Hal Massey Hal thanks for the reply, sadly I'm not a builder.
I have been looking at this https://www.ebay.co.uk/itm/10M-2000MHz-RF-Power-Amplifier-1W-HF-FM-VHF-UHF-Amplifier-FM-Transmit-1W-PA-/114919055834?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l49286&mkrid=710-127635-2958-0 wonder if it will do the job.
On e-bay 1-512MHz RF Power Amplifier 1.6W HF FM VHF UHF F/ FM Amateur Radio Walkie Talkie
I use 2 of these in my Home brew Transverter / Amplifier controller. You can see it on my QRZ page. They are reliable and will drive my 2 m amp to 40 watts for FM use. I know that you are not a home builder, but for two meters should be ok, but you would need a t/r switch or use separate antennas for RX/TX on 2 m. Separate antennas would avoid any need for the switch. You would use XVTR out for TX, and RX in for input signals.
Please be aware that I tried at least 3 different amps (different designs) two failed after a period of time. Also make sure to put a reverse bias diode on power input of the amp. Reverse. Current from a relay can destroy these amps. I have 3 of the current design and work reliably. Forgot to add this to previous post.
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
