SmartSDR v3.9.19 and the SmartSDR v3.9.19 Release Notes
Desktop vs laptop
Santiago Mejia HI8O
Ok, let’s get the debate open (for a while). Which is better for a shack computer, a laptop or desktop. Consider this:
- neither is going out of the shack
- only for ham radio stuff
- will handle a Flex 6300 (SDR), WSJT, DDutil, Logger (Log4Om, FRLogger), SDR Monitor, PST Rotator, internet browsers, and other software.
- Also will handle Icom 7300 with Win4Icom
- must handle 3 monitors
- Rotator control must be connected
- Green Heron Select8 must be connected
- Asume similar prices
Let’s try to have a clean debate please.
Santiago
HI8SMX
Santiago
HI8SMX
Desk top hands down. You will have a hard time adding additional features to laptop as to video and audio handling and more than 2 monitors unless you spend more than what the average desktop costs. Also fixing a desktop is far, far easier if a drive or video card crashes plus you get to upgrade as you go. Just one guys opinion.
4 -
Desktop. More **** for the buck in hardware. New PCI-e video cards can natively handle three monitors. Easier to upgrade and repair.
why three monitors? For $400 I bought a 50” Sony 4K TV that connects to the Nvidia video card in the PC. Plenty of real estate for multiple programs. No monitor bezels to create gaps in video displayed across several monitors.
see my QRZ page for my layout. (Or at least the layout that day).
With Black Friday and cyber Monday coming there should be some good deals.
Dave wo2x1 -
Dave, where the shack is located (closet) I can’t fit a TV or larger display.I expect to take advantage of those specials.
santiago0 -
I like my Intel NUC. Takes up hardly any space.1
In that case buy what works for your shack. Laptop with an external monitor can give you two displays for additional programs. Dave wo2x2
Yes, see a picture of my shack a couple of months ago (Pre-Flex), now it’s getting a make over to accommodate the Flex and an Acom 600S I’m getting later this month.
I managed to fit 3 monitors but can’t do a lot more.
Yes, a small, micro desktop. With careful research you can find a model that natively supports multiple monitors and if you search for an off-lease refurb model you can save a lot of money and have a more-than-adequate computer for your needs. A laptop-based solution for such an application you'll find yourself working against the design of the laptop.0
Full size desktop. For $1400 I got an i7 8700, RTX 2080, 2X 1TB SSDs and 32GB of ram. Easy to add to and work on. The SSD drives have no moving parts. For $40 I added a 2TB hard drive that is only used monthly to back up my SSDs. I have gone through several Win10 updates with zero issues.0
Desktop, easy to expand, loads of space, cheap to buy. Lenovo Workstation, bought 1 year old, recond 600 Euro. Intel Xenon 3.7 GHz, 32 GB RAM, SSD 2TB, 2xNVIDIA graphic card w. 4 24" screens.
Desktop , definitely. laptops, although they do all the Job, are limited in connectivity and extentability.
More Screens, more USBxx incl. upcoming Versions, higher Bandwidth possible at Networks incl. Fibre etc. etc.
Laptop is good for travel or second rig in parallel.
Using an old dell T5500 and a 12" Lenovo 230 Laptop here.
What video card is required to drive a single 50 inch 4K monitor for non gaming use ?0
I also vote a desktop, get plenty of RAM. 32 GB is a good start. Go SSD drives too. With a desktop you should have the space to put rotating drives in as well.
I'd also suggest a reasonable video card. Many desktops come with video on the motherboard which is generally good but may not have enough ports to drive all the monitors you want. So I'd suggest looking at NVidia video cards and pick one that supports the monitors you want.
I realize you don't have a lot of space but you could consider some bigger monitors and the use of monitor arms to support them.0 -
I use a little Intel NUC with an I7 processor with 32gb ram and put in a SSD. works great and is only 4" square.0
An Nvidia GTX1060 should handle desktop 4K use OK. This includes YouTube videos.
I would suggest the NVidia GTX1660 as it is a little faster and has 6 GB ram. They go for under $250 USD.
I'm sure others may chime in with suggestions.
Here I am running an NVidia GTX 1080Ti which has 11 GB ram. This is connected to a 50" Sony 4K TV I use as a monitor. I use the desktop for both shack PC and gaming PC thus the higher end video card.
Thanks everybody for your comments and experience sharing. I guess desktop is likely the best option, but that doesn't mean that laptop have its advantages too. Now it's just a matter of setting my budget and start watching the sales season.
Thanks.1 -
Finally I found a very interesting solution with a mini pc, but really powerful (XEON processor but you can choose other procs). At first buy, I was little scared about the quality of this pure-chinise pc, but when I got it I was nicely impressed really: it works a lot better than any prevision. Very good for SmartSDR v.3 and with DAX too. I keep 24h a day switched on.
Search for Eglobal on Aliexpress:
https://www.aliexpress.com/item/32959303503.html?spm=2114.12010612.8148356.3.308264c6X9IWX7
Interesting.0
I use an Antsle XD VM server and I use a windows 10 VM on it. I had some bugs to work out but I can access my machine anywhere in the world. I have it backed up to the cloud each night. I don't sit at a desk at home and operate. I don't need large monitors with waterfalls.
If I wanted a "command center" style setup it would be a top of the line PC with the latest fastest processor I could afford. Maybe an 8th gen i7?
Why not a laptop? If your not going anywhere and you run a laptop 24/7 (my radio is on 24/7 and reporting what it hears 24/7 unless I'm using it) then you will **** the laptop battery. Laptops are not made for constant use even it some will handle it, it was never its purpose.
Why take a butter knife to a steak shop?
My 2 cents worth and with all the discounts I may own you some change...
Brian,
What model of PC are you using?
Thanks,
Reggie
iBuyPower. Bought it last November. I added the second TB SSD and the 2TB backup drive and more RAM. The nice thing about large desktops is the ease of upgrading.0
At the end, here’s why the budget allowed, 9th gen i9, 32GB RAM, 500 GB SSD, 1TB HDD for backup, RX480 video card (sorry no Nvidia). This shall get the work done.
More than aduquate for shack PC Dave wo2x1
I us use a laptop, but not recommending it, for it can be a struggle to get the additional monitors working. Fortunately, this one has a DisplayPort video.
Using WIN 7, it runs SmartSDR and 2 instances of WSJT-X quite nicely with 4GB ram. $75 hamfest deal.
SmartSDR doesn't need a lot of processing power, but network throughput is critical to keep everything connected and working
- 339 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 171 SmartSDR for Maestro and M models
- 401 SmartSDR for Mac
- 264 SmartSDR for iOS
- 248 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.2K Radios and Accessories
- 19 Aurora
- 193 FLEX-8000 Signature Series
- 915 Maestro
- 53 FlexControl
- 859 FLEX Series (Legacy) Radios
- 887 Genius Products
- 450 Power Genius XL Amplifier
- 321 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 442 Remote Operation (SmartLink)
- 137 Contesting
- 742 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 957 Third-Party Software
