SmartSDR v3.9.19 and the SmartSDR v3.9.19 Release Notes
RCA TX does not operate
Martin
On my 6300, if I select RCA TX 1, it does not work. No keying on my accesories (relay)
I have tested every posible combination and nothing.
No other programs running on pc.
It is like this since new version with different settings for each band (v2.5.1)
I plug my amp relay box in this jack on the back of my 6300 and it works fine w/3.0.27 ssdr
And i set up the controls for each band accordingly
It does work for me this way. even when I run remote.
As Jim already commented, this menu is a NEW item under "Settings" and it is called "TX Band settings..." on the 6700, 6500 and 6600 (not sure on the 6300) you click ON the "RCA TX1" if your running Amp keying on that port on the bands you want to use the Amp/relay on.
Bret
SOLVED.
I do not know how,but after various resets, now it works
Thanks everybody
- 345 Community Topics
- 612 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 173 SmartSDR for Maestro and M models
- 407 SmartSDR for Mac
- 266 SmartSDR for iOS
- 249 SmartSDR CAT
- 186 DAX
- 374 SmartSDR API
- 9.2K Radios and Accessories
- 20 Aurora
- 201 FLEX-8000 Signature Series
- 919 Maestro
- 53 FlexControl
- 860 FLEX Series (Legacy) Radios
- 891 Genius Products
- 453 Power Genius XL Amplifier
- 322 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 442 Remote Operation (SmartLink)
- 137 Contesting
- 750 Peripherals & Station Integration
- 138 Amateur Radio Interests
- 971 Third-Party Software
