SmartSDR v3.7.4 and the SmartSDR v3.7.4 Release Notes | SmartSDR v2.12.1 and the SmartSDR v2.12.1 Release Notes
SmartSDR v1.12.1 and the SmartSDR v1.12.1 Release Notes
Power Genius XL Utility v3.8.8 and the Power Genius XL Release Notes v3.8.8
Antenna Genius Utility v4.1.8
Can I use GNU Radio software with FlexRadio hardware?
James Cosby
I would like to experiment with GNU Radio Companion or python code using the GNU Radio library. Is this possible? Does anyone have experience with this?
Hi, also currently working on the project myself
Found out that you can download the Flex radio API form the website
and create a new wavwform API using https://github.com/n5ac/smartsdr-dsp1 -
It would be nice to have a gr-osmosdr driver for the 6000. I'm in the process of learning C++, and hope to try to do it. http://sdr.osmocom.org/trac/wiki/GrOsmoSDR1
Maybe a good point to start from might be to first get the IQ Data ( https://community.flexradio.com/flexradio/topics/how-to-use-flexlib-api-iqstream ) and a Vita-49 UDP Source GNU Radio block? No Idea if that is the right path, but I'm about to give it a try Anyone already created that Vita-49 UDP Source GNU Radio block like in this doc: https://www.ettus.com/kb/detail/building-a-32-channel-system-with-the-qr2100
Not as cool as a gr-osmosdr driver but - Proof of concept
https://www.youtube.com/watch?v=sgKFeRvCUFs
That's awesome, how do you link the IP address of the generated data stream in C++ to your source block. Sorry, couldn't review the code properly.0
It's C# running on the windows machine. Currently not the smartest way of transporting and packing the data but enough for a proof of concept...
Socket sock = new Socket(AddressFamily.InterNetwork, SocketType.Dgram, ProtocolType.Udp);IPAddress serverAddr = IPAddress.Parse("<<GRC Machine IP here>>");
In the dataReadyEvent:
IPEndPoint endPoint = new IPEndPoint(serverAddr, <<"GRC udp source" port here>>);
sock.SendTo(<<<IQ data byte[]>>>> , endPoint);0 -
Another prototype, only linux involved now. No windows box or proxy between. Using Mono...
var stream = ConnectedRadio.CreateAudioStream(1);
pushing the float[] into FIFOs, IQ directly into Gnu Radio, The audio goes to aplay -r 48000 -f FLOAT_LE out.raw
stream.RXDataReady += rxdataReady;
stream.RequestAudioStreamFromRadio();
var IQ = ConnectedRadio.CreateIQStream (1);
IQ.DataReady += IQ_DataReady;
IQ.RequestIQStreamFromRadio ();
var IQ2 = ConnectedRadio.CreateIQStream (2);
IQ2.DataReady += IQ2_DataReady;
IQ2.RequestIQStreamFromRadio ();
Writing is just like:foreach (var rx in data) {
Performing fine, guess that's the right way to go for Audio / IQ. CAT will be pretty simple. Rendering Panadapters / Waterfalls will be HTML5.... not yet tried to get the Opus stream.
write2.Write (BitConverter.GetBytes(rx));
write2.Flush();
https://www.youtube.com/watch?v=PO0I97daOuU
Nice, so when you get data streams from the flex radio do you just create a gnu radio block that decodes using the code.
It's just taking the raw floats from the 2 IQ channels, that I've subscribed and does a FFT on it. The audio is DAX Audio channel #1, goes via fifo into aplay. It's more about exploring how to continue. Experimenting, and trying to first bring the DAX client to linux/PULSEAUDIO The result should look ~ like:
Hi, On your Dax IQ data to Gnu radio proof of concept do you run the SmartSDR software on windows then the Gnu radio GRC on linux. Im kinda conflicted because my SmartSDR only runs on Windows while my GRC runs on my linux. If I wanted to perform data stream setup for the UDP socket I can't view my IQ data waterfall and also run GRC on linux simultaneously.
No, no SmartSDR, just the API. I'll publish an utility very soon, that can be used as a starting point.0
Started to push things to Github. A first small sample is published, to sned DAX IQ data to an UDP socket:
https://github.com/krippendorf/FlexlibMono
Descriptions in the repo.
Impressions: GRC & Baudline:
Awesome, how do you generate the
Im guessing you use this window to input the util for pushing data to gnu radio
Generate the ?
The data is pushed in line 107, as it arrives https://github.com/krippendorf/FlexlibMono/blob/master/src/HB9FXQ.Queryutil/SampleFlexWrapper.cs#L10...0 -
oh sorry, i didn't communicate my question well.
I meant if I wanted to start using the util for pushing data into gnu radio, how I begin.
I already downloaded the github files you posted but confused at the part where you say "start the util in a shell".
Don't know what shell your referring to.0 -
Sorry, guess what I'm saying is how do I run the SampleFlexWrapper.cs code on linux. When I run the code I get an error at Using flex.util, Using flex.smoothlake.flexlib and Using ZeroMQ. At line 23, 24 and 25 of the code.
How do you get those to work. Thank you.0 -
I'll update the readme tonight, you have to compile the code, to run it. Details soon. What you'll need is the latest version of mono: http://www.mono-project.com/download/0
I keep getting an error when compiling
sorry not made it today, just a short hint again: latest mono version, fresh git clone / post the full build log then please0
ok Thanks.
I currently have the latest mono version, a fresh git clone.
I then progress to the src file then open the FlexlibMono.sln
I then click on build all on the monodevelop window
Then I get the error from the SampleFlexWrapper.cs code
This is the area I'm stuck at
Also the PresentationCore and PresentationFramework references arent available0 -
ok, might simply be the build order. Travis on Github also has no issues. That is one reason, why I setup the Travis CI... To resolve: Click each proj (Vita, Util, UiW... first ) and press F7 to build on each, Flexlib/Queryutil last. Then rebuild the Solution. It's a very common Situation with sln files. Hope, that helps.1
Thanks I was able to generate the code. I am receiving packet from the radio but my gnu radio"udp source block" doesnt seem to be receiving the waveforms as seen below
Have you selected DAX channel 1 on the panadapter, that you want to stream? Its in SmartSDR on the panadapter (top left). Should be easy to get this running now0
yeah, i did make my DAX channel= 1 on panadapter.
I used wireshark to confirm that my computer Ip address receive VITA 49 packets but the UDP block in grc doesnt seem to receive those packets or at least generate a waveform0 -
Hi Frank, do you by any chance have the VITA49 UDP block or packet. I think the radio only send packet in this form and an ordinary UDP can't read the packets. Thanks0
Well, I don't have that VITA49 block, but have just now verified, that my code is working. I'll try to push a version on the weekend with more debug output, to see what's going on. Have you tried to set a breakpoint to see what actually happens?
Stay tuned for an updated. Work in progress
For now: I've just quickly pushed a commit to github, so that you'll see an info on the console, that IQ data is actually being send.
Maybe you also want to try to replace 127.0.0.1 with your local IP address.
sorry from the mobile, but your screenshot shows audio dax, not iq. see the dax button on the panadapter on the left.0
Hi, finally had grc receiving the packets but it takes forever to generate the waterfall plot and the fft plot is still non existent. Does this relate to the frequency i'm tuning into from my flex radio.0
- 250 Community Topics
- 489 The Flea Market
- 7.4K Software
- 5.9K SmartSDR for Windows
- 135 SmartSDR for Maestro and M models
- 331 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.6K Radios and Accessories
- 6.9K FLEX-6000 Signature Series
- 779 Maestro
- 42 FlexControl
- 836 FLEX Series (Legacy) Radios
- 731 Genius Products
- 392 Power Genius XL Amplifier
- 254 Tuner Genius XL
- 85 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 375 Remote Operation (SmartLink)
- 119 Contesting
- 584 Peripherals & Station Integration
- 116 Amateur Radio Interests
- 810 Third-Party Software
