RTTY ,split more 10khz with DW780, DAX, flex 6300
on5po
- 23 Posts
- 0 Likes
hello, who could help me how to open the second chanel of the DAX
I only have dax chanel 1 open
to be able to make the split in rtty of more than 10Khz
I have win7,64 bits, flex 6300, and DM780
so possible with photos
thank you for advance
on5po@hotmail.fr
on5po, Janny
Janny,
Running rtty split with two DAX channels requires that you use two slices..used DAX 1 on slice A and DAX 2 on slice B. In your RTTY program, select DAX1 RX for receive ( caputre ) and DAX 2 TX for transmit ( playback). You should see appropriate displays in the the DAX control panel. with DAX 1 enabled for RX and DAX 2 enabled for TX.
AL, K0VM
Thank you Al, my problem, I only have a chanel the 1
I don't know how to make to have the chanel 2
the chanel 2 doesn't function in TX
janny, on5po0 -
Janny,
How many channels show up in the DAX control panel? Can DAX 2 be enabled for TX? If you go the windows control panel>manager audio devices, do any DAX 2 channels show up there ?? ( you may have to enable' show disabled devices' )
You may have to uninstall and reinstall DAX.
In your RTTY program, do other DAX channels show but DAX 2 is missing ? There is nothing magic about DAX 2 if another one is available.. Some RTTY programs can not display all the DAX channels that are installed.
AL, K0VM0 -
AL,
In the DAX, chanel 1 and chanel 2 I have RX in dm780 waterfall in chanel 1 TX... ok
chanel 2 TX no... no power ptt of dm780 toward flex.... why?
I don't know or go have ptt to the chanel 2
veils or is my problem
Janny,on5po0 -
Al,
rectification not of RX and TX with chanel 2
only chanel 1
sorry
my problem is to know or go activate the chanel 2 in RX and TX
Janny
Janny,
What DAX TX devices show up in the Windows Audio Device Manager ? Do They show up in your RTTY program ?
AL, K0VM0 -
Al,
I have 8 X DAX (only) reserved audio TX
how to make to have DX audio TX
it is my problem I am not very strong to compute of it, sorry,
Janny0 -
Janny,
Does your DM780 Soundcard transmit selection look anything like this ?
Please attach a picture.
AL, K0VM
Al, I have modify in DM780, as asked, to see capture
chanel 1 RX.. ok, chanel 2 no tx
Al I only have the TX with chanel 1 and DAX audio TX1(DAX TX Audio)
in DM780, Soundcard, with DAX Audio TX2(DAX TX Audio).... TX no
Janny0 -
That looks okay.. Since you are showing signals in the Windows Audio Control panel for Reserved TX2, that means that signals are being presented to the radio. See attached..
Note:: In lower right corner.. High cutoff must be above tone frequencies.
Note DAX button must be enabled in the P/CW panel.
Note: During transmit,the level meter indicates signal.
Your close..
AL, K0VM
Al,
With tune--> OK --> indicate signal
Chanel 2 B in, with send or macro of dm780--> below TX lit no power,, DAX--> lights --> no indicate signal
Janny
Al,
now it is OK, I had forgotten to light the chanel 2 and TX in DAX control panel
you are the best
thank you for your patience
the only problem, when I want to use with the TX A, must change in soundcard dm780 to come back has DAX audio TX 1 for split........ I must work with DAX audio TX2
does have every time to change?????it is normal
ON5PO, Janny
- 378 Community Topics
- 630 The Flea Market
- 8.2K Software
- 116 SmartSDR+
- 428 SmartSDR for Mac
- 271 SmartSDR for iOS
- 258 SmartSDR CAT
- 191 DAX
- 382 SmartSDR API
- 9.3K Radios and Accessories
- 37 Aurora
- 254 FLEX-8000 Signature Series
- 945 Maestro
- 55 FlexControl
- 923 Genius Products
- 462 Power Genius XL Amplifier
- 336 Tuner Genius XL
- 125 Antenna Genius
- 296 Shack Infrastructure
- 208 Networking
- 458 Remote Operation (SmartLink)
- 139 Amateur Radio Interests
