Flashing red power switch
How many times is it flashing? If you count the flashes and look in the hardware manual it will tell you what the fault is.
I am guessing the letter O means three?
One red flash: Fan malfunction
• Two red flashes: Software crash
• Three red flashes: Boot failure
I get Two guaranteed every time I go on CW at over 80 watts and don't hit the ATU no matter what the SWR is prior to hitting the ATU.
The OP stated it flashed "like a letter O" so that would be 3 flashes and according to previously posted information, that indicates a boot failure. Time to open a Help Desk ticket.0
Roger, have tried a cold reboot? I have a 6700 so the procedure is probably different, but it will be in the manual. Something like holding the power switch until the rig shuts down completely, remove power for 60 seconds, replace power and turn the rig back on Otherwise, as Greg mentioned, time to open a Help Desk ticket Good luck Winston0
Try disconnecting power cord from the radio 20 seconds then plug it back in and try again.0
I guess I skipped a couple of critical points. Yes, a complete power disconnect for 20-30 seconds, then reconnect and restart. A factory reset can also be tried. If all that fails, go to the Help Desk!0
Hi Roger,
I have the same symptom with my recently delivered 6600 - opened a Help Desk ticket this afternoon.
Were you able to resolve the issue in the field or did you have to send it back to Flex?
- Hunter K3IE0 -
I have same problem today. Red light flashing three times. Reset mane times - nothing. Any idea?0
Did you remove power for 10-15 seconds (disconnect the Power Pole connector to be sure), then replace power, and then press the power button to initiate a normal startup? If that does not work, then a help desk ticket is indicated.
Try removing the network cable and restart the radio.0
Yes, many times - same result. Flex turned ON, show Flax 6600m on scree, after thet red light start flashing. “please wait “ on screen.....0
Yes sir, I did (0
If you are able to get the radio to start again try to configure the radio to use a static IP address. There have been issues with the radio having issues starting when using DHCP addresses.0
Even without network cable I cannot start radio0
As mention, can you set a static Ip address and try?1
No, because radio did not turn ON. Or I missed somewhere?1
I think you can set the static address in the router? I am saying this because a few other were having problem like this and they had to set to staic address.1
I was ship radio to Flex service.... get back in a week. All working good now0
if you reset the static address on the router will it affect the way it receives the internet?0
I have just raised a help deck ticket for a similar sort of problem. I can get SmartSDR for Mac to work ONLY if I disconnect the ethernet cable first, then boot up the 6600M, and then plug in the cable afterwards. At least I can boot up the rig and work the DX still!!
By the way, I have not touched my internet router so I do not see how the IP address or DCHP can change of it’s own accord.
Check out my report on Flex Signature Series category.
Regards. Mike G4GWH.
This old thread saved my anxiety. Just arrived 6600 booted fine but after a few minutes I got the 3 red flashes . Removing the power cable for 20 seconds appears to have solved the issue...
Andy K3UK
To help you out, we really need some more details on how your network is configured. What is the IP address of the radio, the computer, etc.
Even though you have not touched your router, things are still subject to change within the DHCP services. Don't assume it hasn't changed without confirming it just to be sure.
I received my new radio yesterday, had the same issue today. It wouldn't boot with the network cable attached: eventually the power button would flash red 3 times in a row. I disconnected the network cable and got it to boot, then I set a static IP. Upon reboot, it booted to 3 red flashes again. I removed the network cable and was able to boot, reconnected the cable once I saw the solid green, and connected via the static IP.0
This needs to be handled by our support team. You'll need to follow up with them.
New problem in 6400. Try to shut it down, and just get an Orange Power button. If I hold it down, it turns into Red, blinking 6 times. I have to remove all power, including Pwr pole connectors to pwr supply. Then, I can start as usual for past several months. Can't find anything about 6 flashes, either Orange or Red. Appreciate any suggestions. TIA0
From the Flex 6400 and Flex 6600 Hardware Reference Manual:
Error Conditions
Certain hardware and software error conditions cause the radio to stop operating and display an error code by flashing the Power button light as follows:
• One red flash: Fan malfunction
• Four red flashes: Input power over voltage
• Five red flashes: CPU overcurrent
• Six red flashes: Input power under voltage
In the case of a software crash, the error code repeats for about 15 seconds, then the radio will reboot. In the other cases, the error code repeats until the Power button is pressed, then the radio shuts down. An additional press of the Power button is needed to restart the radio
6 Flashes is bad 12DC power. Make sure all cables are secure and that your power supply is putting out about 13.8VDC.
Mike & Len - Tnx. Have an adjustable pwr supply with vague analog meter, so bit of a guess. Does the Flex record/display input power ? Have a few rigs that will show input pwr level. Increased output pwr of supply & fixed problem Red Flash problem. TIA Bob K4RLC0
Try using FRStack. It has a meter display that will show you voltage at radio. Check on RX then with 100 watt carrier in tune mode. If you see a significant drop between RX and 100 watt TX the. Investigate your cable connections or internal fuse socket in radio.
@k4rlc - If you have a multimeter, you should measure the power at the power supply and at the radio.
- 244 Community Topics
- 481 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 162 DAX
- 348 SmartSDR API
- 8.5K Radios and Accessories
- 746 Maestro
- 41 FlexControl
- 722 Genius Products
- 250 Tuner Genius XL
- 84 Antenna Genius
- 225 Shack Infrastructure
- 150 Networking
- 120 Contesting
- 114 Amateur Radio Interests
- 805 Third-Party Software
