Flex 6700, now all slices slaved to one antenna??
W2PP
I hadn't had this problem and now suddenly I do. I have a 6700, when I try to have Slice A on one antenna and Slice B,C,D on others, they all **** to one another. Whichever antenna last chosen puts them all on that antenna. Dunno, never saw this before.
Suggestions?
Peter
Suggestions?
Peter
Are the slices all on the same panadapter?
Receive antennas are actually associated with panadapters and all slice in that panadapter inherit the same RX antenna.0 -
You need to put different freq. on different panafall snot slices if you want to use different antennas0
I should have been clearer. Here is what I have then I'll say what happens
Slice A 20 meter Antenna 1 panafall 1
Slice B 80 meters RX B panafall 2
Slice C 160 meters RX B panafall 3
Slice D 17 meters Ant 1 panafall 4
Slice E 40 meters Ant 1 panafall 5
Sorry just edited this realized it wasn't clear, these slices are all on different panafalls.
So, if I change A, or D or E then A,D,E all end up on the same antenna. I want to get Slice E off on antenna 2 its a multiband antenna Even if I put A,D,E on RXB the all then go there and I can't unlink them.
I'm doing something wrong
Peter0 -
I just edited the post to make it clearer they are all on different panafalls.0
I rolled back to 2.033 and the issue remained so its not a platform issue. Reinstalled latest same result.
Don't know what else to do here????
Peter
Peter, I am sitting in front of my 6700 today so if you would like to recreate the issue on mine to see how it reacts shoot me an email and we'll exchange numbers. Good at QRZ. Although I think your slice E is getting associated with the SCU of slice A so you may need to swap some frequencies around on the slices to get the association you desire.
Thanks for some reason its now working, weird but at least its working......no clue why.....
I'll see how it behaves over the day......0 -
Awesome!!!
This is exactly how the radio will behave. In your case, ANT-1 is on the 1st SCU and RX-B is on the 2nd SCU. If you change the ANT-1 on one panadapter, all panadapters associated with that SCU will change their antenna to match. WHich is what the radio did.
The SCU is associated with a panadapter, not a slice receiver. A slice is a resource that is dependent on a panadapter, so if you change the slice RX antenna, that changes the panadapters RX antenna. And the SCU associated with that panadapter antenna assignment will change all other panadapters associated with that SCU to the new RX antenna.
I hear ya Tim, just keep in mind this gets a bit confusing with SCU 1,2 Pana 1-5 and Slice A-E!! I'm trying to wrap my head around it, it will take some time, lots of moving pieces here.
Wonder why Ii now got it to work? That's the part I'd like to understand.
Peter
Without knowing the exact and complete steps you took to resolve it, it would be challenging to speculate why you were able to resolve it. The software goes to great lengths to dynamically allocate radios resource in such a manner that the maximum amount of radio resources are made available at any given time and that the radio is not put into a configuration that would prevent an available resource from being used.
It can be confusing, but in general, it handles 99% or better of all of the multitude of configurations the radio can be put in with 2 SCUs, 5 or more possible RX antenna ports and the up to 8 panadapters that utilize the SCU/RX antenna port combination.
- 246 Community Topics
- 488 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 163 DAX
- 348 SmartSDR API
- 8.6K Radios and Accessories
- 766 Maestro
- 41 FlexControl
- 733 Genius Products
- 255 Tuner Genius XL
- 85 Antenna Genius
- 229 Shack Infrastructure
- 153 Networking
- 120 Contesting
- 115 Amateur Radio Interests
- 813 Third-Party Software
