Broken DAX channel
W2PP
I'm using Slice Master. DAX channel 3 was OK. Then I inadvertently closed a program hooked to DAX 3 via Slice Master. Now, no program gets audio from DAX channel 3. DAX 3 shows audio on the DAX control panel. Tried resetting computer no change. I looked inside HRD, under the sound card selector. I found double DAX 1, 2, and 3 channels. I'm using 1 and 2. Doesn't seem to matter which number 1 or 2 I choose either works. I looked inside Device Manger, com ports appear normal. I looked under audio devices inside Device manager, the Flex stuff looks correct there as well. Using latest SmartSDR and 6700 Win 10 1803. Not sure this has anything to do with the latest windows update at all.
Suggestions???
Peter
Suggestions???
Peter
I almost hate to ask the question, but have you powered down and rebooted everything?
Bob, WK2Y
Bob:
OK, I powered down re booted. So DAX 3 is working. However, I have double choices for DAX 1, 2,. They seem indistinguishable functionally. All that I posted otherwise in the original post remains true. All OK under Device Manager with respect to COM ports and Audio devices.
Peter
Double choices? Do you mean under the RX streams you see DAX 1 twice and Dax 2 twice? That's bizarre.0
That is correct, I see double choices for DAX 1, 2 and 3. Choose either one, they work.0
I have no clue...but that's not unusual.0
Tim,
I followed your dicrections here https://community.flexradio.com/flexradio/topics/important-notice-windows-10-update-1803-precautions
And it worked for me. Nothing else would. Thank you for posting it. Redmond never did do a good job of copying the Mac OS.
Dan0 -
Peter (W2PP) if you are still having DAX issues and none of the recommendations on the Community have helped, please open a HelpDesk support ticket.0
- 244 Community Topics
- 481 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 162 DAX
- 348 SmartSDR API
- 8.5K Radios and Accessories
- 746 Maestro
- 41 FlexControl
- 722 Genius Products
- 250 Tuner Genius XL
- 84 Antenna Genius
- 225 Shack Infrastructure
- 150 Networking
- 120 Contesting
- 114 Amateur Radio Interests
- 805 Third-Party Software
