Lost connectivity with radio.
Bob G W1GLV
Working a QSO and all of a sudden the radio lost connection with the network. The radio is connected directly to the router. The computer that runs SSDR is connected via a switch. After this happened I ping the radio and got good resultss for 34 pings, this tells me the radio is connected via the network. Then I restarted the radio, still no connection. After rebooting the computer everything was ok. The computer I'm using is a NUC. Using SSDR 2.0.19. Running Win10 on the NUC.
If you can provide more details it will help.
- Make and model of Router, switch, and NUC
- Specs on NUC CPU, RAM, ethernet
- What else was running on the NUC
- What was/is the CPU and RAM usage level
- What other devices and their activity that are connected to the Router and Switch
Can you connect the NUC to the router temporarily to remove the switch from the equation? I discovered I had a bad managed switch that was causing issues.
I wonder if the lease time of the IP address expired...It is usually 1440 minutes (24 hours) Could it have renewed it's IP address and lost connection briefly?0
That's the first thing I checked. The radio has been on for a few hours and all is ok for now.0
Try making the NUC and Radio a static address to avoid that possibility. If not you might be able to set the expire time higher.
I will connect the NUC to the router directly and I'll report back.0
The radio and the NUC are static IP's.0
I have noticed with 2.x that even on my lan, if I'm wireless via laptop to the network sometimes I just get disconnected. Re-start of my computer and SSDR brings it back.
My wired computer next to the radio is rock solid. Could be wifi stuff in my case.0 -
Losing a lease is very unlikely if the radio is connected and communicating with the network.0
Mine did this today as well, turn out to be the **** AVAST firewall changed my home network From "Private" to "Public" and killed SmartSDR, DAX and CAT.
Wasted about an hour checking out everything until it dawned on me the dam firewall changed states.
73's
Bret
WX7Y0 -
Are you saying that if the lease time expires while connected it will reset by itself without loosing connection? (I am just trying to learn how it works)0
Typically if the IP is active the lease shouldn't expire. It should just renew. It can depend on the device and how it has implemented DHCP. A google search will turn up results where people were expiring drops on expire in general use not specific to Flex.
To add a little more detail to David's explanation, at the point where a lease has hit 50% of its lease duration, the host (PC or radio), if operating properly, will request a DHCP lease. All DHCP servers on the network will respond to this request. The host will decide which DHCP OFFER to accept and if the DHCP server that provided the previous IP address leases responds, the host will accept that one which effectively becomes a lease "renewal" and the cycle continues until the new lease duration time hits 50% of its duration.
If the DHCP server is not available on the network to respond to the host's DHCP lease request (DHCP DISCOVERY), the host will continue to send a request for a DHCP renewal at various intervals, waiting for any DHCP server to respond. If there are no DHCP servers to answer a lease request and the lease expires, the host will have it's IP address lease revoked. What happens next is OS dependent, but in general the host should self-assign a link-local (APIPA) IP address to the interface.
If the host is shut down during an active lease time period, when it is rebooted, it will request a DHCP lease. If the lease on the DHCP server has not fully expired, the host will get the same IP address it had previously. Some DHCP servers will cache expired leases so that if the host reconnects after the lease expiration time, it will get a lease that has the same IP address as it had previously, maintaining IP address continuity (but guaranteeing it).
DHCP is a robust protocol. I have set up enterprise DHCP processes that serviced 10,000+ hosts on a single enterprise network and it just works reliably unless there is a server or network communication failure.0 -
I would like to point out that many Microwave ovens operate at 2.4 GHz range and when they are leaky they knock out WiFi over a wide area. I have had this investigated and proven on several occasions at hotels where The WiFi is on 2.4 GHz. I just wanted to mention this in case it it relevant tho those who are loosing WiFi connections I use the WiFi analyser from "Rig Expert" to detect and resolve this..... Just changing to 5 GHz (On both ends) and seeing if the problem goes away can help in the search...0
And how easily we forget about USB 3. See the following white paper by Intel.
https://www.intel.ca/content/www/ca/en/io/universal-serial-bus/usb3-frequency-interference-paper.htm
Just having a USB 3 dongle or poor cable can wipe out a wireless keyboard, so why not a wireless "wireless" radio.
- 246 Community Topics
- 488 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 163 DAX
- 348 SmartSDR API
- 8.6K Radios and Accessories
- 766 Maestro
- 41 FlexControl
- 733 Genius Products
- 255 Tuner Genius XL
- 85 Antenna Genius
- 229 Shack Infrastructure
- 153 Networking
- 120 Contesting
- 115 Amateur Radio Interests
- 813 Third-Party Software
