Tutorial Video: A Tour of Transmit Profiles on my 6500
Ken - NM9P
Member ✭✭✭
Here is a tour of several of my Transmit profiles, and why it is necessary to have several different ones, depending upon your purpose. BONUS: How to make a 6000 Series sound BAD! It can be done!
It is a little long, about 22 minutes with a couple of "tongue-tangles."
I hope you find it useful, and excuse a couple of "preachy" spots.
https://www.youtube.com/watch?v=3s7UbKiqxAA
Equipment:
Flex-6500
Heil PR22UT Mike
Behringer Q802USB Mixer (for distribution, not equalization)
Audio/Video Capture - Open Broadcast Software (OBSProject.com)
Equipment:
Flex-6500
Heil PR22UT Mike
10
Thanks, Ken. I like it! -Dave W6OVP.
That was great! I can see that video becoming one of the standards people watch for learning to adjust their audio0
Now how about a 5 minute "Executive Version" showing only how to set up a 6000 audio with its factory mike right out of the box. That would have helped me a WHOLE LOT when I first got mine. TNX.
I experimented a little with Kens method. I set up FDX and separate TX and RX slices.
I then recorded a sample with the TX A slice. then transmitted the A slice sample while recording it with the B RX slice. Comparing the 2 recordings I couldn't tell much difference, other than the volume level they played back at. Now I've got a better idea how close the two sound though.
Good video's Ken, keep doing them.
73, Jay - NO5J0 -
Jay, I tried that, too. So far, I haven't been able to confirm that using the internal recorder on slice B is actually recording what it is hearing, or if the transmit routine's recorder is taking over the recording routine. It does, however record the actual received audio when you port Slice B over to Audacity with DAX. I need to do more experimentation, specifically to see if other signals on the frequency are also recorded. Ken - NM9P0
I plan on doing some more, detailing step-by-step procedures on setting up a new mike and adjusting the mike levels, EQ, processor, etc. but it will probably be next week. The last one took me about two hours to record and upload. (I had a couple of bad recordings due to noise in the studio/shack and phones ringing!)
As far as the stock mike...I will see what I can do. But it will never sound like a good studio mike.
Additional tutorials will not be as long as this last one. I tried to tackle too much in one recording. I should have separated the "how to make the Flex sound bad" section out into its own video.
Ken - NM9P0 -
I think the proof they're 2 separate recordings was in the output levels.
It's that hard to tell the difference in them.
Maybe create the RX recording first, then go back and use a different sentence to record a second TX recording and compare those.
Like "this is slice B, transmitted from A" recorded on Slice B first, then "this is just Slice A" recorded on Slice A.
My guess is the recordings are stored in memory per slice. I haven't tried to prove that, but it's how i'd expect it to be doing it.
73, Jay - NO5J0 -
Of course not. But that's the way it comes to the new buyer. He needs to begin with positive experiences immediately even tho they may not approach perfection.
I was/am one of many who was greeted by bad on air reports until I got on air help and set up the furnished mike optimally. (I bought this 6000 from a buyer who gave up in frustration.) Then I added a new mike and it got even better.
-Dave W6OVP
When I was playing with the internal recorder, I found that it was extremely close to the sound I was receiving when monitoring on my 1500. The advantage with using FDX is that I can listen to my signal as I make adjustments. And I can see the signal on my panadapter as I do it. With the internal recorder I must record and then listen later, and the audio is "blind." I can't see it as I hear it. But, either way works well. It is nice to have options now! Ken - NM9P0
Another excellent video!!! Keep them coming ken!!!0
Yes both videos very well done and informative. Can you do one on global profiles, when you have time. Thanks muchly
Cheers
Wayne
vk4acn
Fantastic video Ken!!! I learned more off this video than in 6 months of fiddling with my 6300. Your video inspired me to try further experimentation with my audio and how to avoid poor audio. Bravo!0
I will need to research global profiles a bit more before I tackle that one. I don't use them very much. I DO use Transmit Profiles quite a bit.0
I hope Flex makes an agreement with Ken in order to produce a movie series "how to".
Fantastic, chapeau Ken...1 -
Good job, Ken.
Ken, thanks for your tutorial. What do you use to produce your Youtube videos?0
I use OBS - Open Broadcast Software, which is an open source program that allows two audio inputs and will do Window capture or whole monitor capture and save in FLV and MPG4 formats.
It is going to be even easier to use now that v. 1.6.17 has DAX Mike output. I won't need to use my USB mixer for the narration mike!
Unfortunately I haven't had much time to do any additional Tutorials. I hope to get back to it soon.
Ken - NM9P0 -
Thanks Ken,
I've had a couple groups that want me to put a presentation together and hadn't found quite what I wanted to use. Hope you'll find time to put more tutorials together.0 -
Rev Ken
That was a very nice video tutorial for the average Flex user regarding audio band width.
Thanks for sharing the info.
Ian
Great video Ken, I really like the idea of running the XVRT port at the lowest power to mimic a low signal. Great idea!!0
I got excited after seeing this video and used the technique of transmitting through the XVRT port on my 6500 in one slice and monitoring/recording in FDX on another slice tuned to same frequency. I adjusted TX EQ to provide good tonal balance based on what I was hearing on playback. I subsequently found that my actual signal being received by distant stations had a tonal balance skewed to the treble as compared to what I was hearing locally with this monitoring method. I therefore must question whether you can reliably adjust your TX EQ with this technique.
Barry N1EU0 -
Well, keep in mind that you can EQ your RX, so can someone listening to you and you can modify the receive passband. I normally take out the bass when I hear someone abusing that lower frequencies. I would be surprise if someone using a flex with the same RX settings as yours doesn't get the same results. Let me know and we can test it one day on the air.
For this to be a meaningful test, we need to be able to save the SSDR recording in a file. Is there anyway to do that? Or do we just use RX DAX and make a recording with a soundcard program like Audacity?0
Yes to the DAX and Audacity.0
My own tests, listening and recording with my 1500 on a dummy load, and comparing with recordings via the full duplex option, showed results that I would call "pretty darn close." Assuming that my full duplex receiver's filters and EQ are set the same as the outboard receiver. Other receivers may have a different response due to different filtering, EQ settings, or speakers. As always YMMV.0
Sal and I will run some tests and hopefully come up with some comparison recordings to help shed light on what I'm seeing with this method.
I would REALLY like this method to be reliable/dependable but it doesn't seem to be working for me so far.0 -
I have a cool way of running my own test. I have a Kenwood TS2000 that I run remotely with RemoteRig. The TS2000 is located in my QTH in Madrid Spain. It is connected to a Hexbeam. I can actually hear myself, as I sound after crossing the atlantic. On different bands and with different conditions I can hear the effects of different settings.
In my case, using an electret capsule with a yamaha CM500 headset I like it better using EQ and no PROC. If I use PROC I have to turn off EQ.0 -
What I like about Ken's videos®©™ is that he does not feel the need to be a comedian like others do, he does not use every single video effect available in his software like others do and really knows his stuff like others do not. Many videos, including many praised here, are just poor efforts which pale into comparison to Ken's productions®©™.
I assume that the day job helps in communicating such involved concepts.
I have downloaded the video to my Flex library and look forward to more.
Many thanks Ken.
Very useful indeed. Thank you Ken. David G4NRT0
With the help of Sal 8P9EH, I just went through an exercise of comparing my locally created recordings (using Ken's FDX/XVTR technique) to recordings that Sal made of me over the air. I'm happy to report that I stand corrected and there is fairly good correspondence between them. I'm not sure why I previously had a mis-compare between my recordings and what people told me I sounded like but I plan on continuing to experiment! Thanks to Sal for his patience and efforts in assisting me!
73, Barry N1EU0
- 245 Community Topics
- 488 The Flea Market
- 7.3K Software
- 327 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 221 Shack Infrastructure
- 149 Networking
- 369 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 809 Third-Party Software
