USB D-STAR BOARD
NDA
Very interesting, I wonder if it will work with a transverter?
Jon...kf2e0 -
I see the NW ThumbDV is now offered for sale on the Flex Website. SSDR V 1.5 must be close to release?
Cal / N3CAL
Fingers crossed! That would be nice!
Cal / N3CAL
I got one on order. To be a fly on the wall at the Huntsville Hamfest0
I met with Bryan and John of NW Digital Radio at the TAPR DCC last year and we got to talking about their board that provides the DVSI codecs to a Raspberry Pi board. I was intrigued and said we'd be interested in doing this with the FLEX-6000, but that we would really need another way to access the data. I suggested a USB appliance and Bryan said he would go make one! The result is the ThumbDV. We have also created an open source module for D-STAR which we will be distributing soon that, when used with the ThumbDV, provides D-STAR as a new modulation mode in the FLEX-6000. The ThumbDV is required because the AMBE codec is proprietary and using the DVSI chip in the ThumbDV is the best way to access the proprietary codec from the radio.
This adds a new mode to the already existing CODEC2/FreeDV mode which can be downloaded from our website and which is also open source. We'll put the D-STAR code up as soon as we have a chance.
Using the D-STAR mode will require SmartSDR v1.5 which we hope to have out soon as well.7 -
Just ordered my ThumbDV, love DSTAR.0
My hope would be to be able to use this through the D-star repeater network. Modulation is just the 1st step. We need to be able to manipulate and send the "my call" "ur call" "repeater 1" "and "repeater 2" fields. Thanks to the Flex and NWDR folks for getting us this far!0
Very cool! Good to see the USB port get some love.
Is there much HF D-Star operation? Any tips/suggestions?
We have an application that runs alongside SmartSDR that allows entry of the callsign data1
Thanks!
Wow. Sounds great. Can't wait!0
Can someone comment on weather this will work on a 6500 with a transverter for 2m or 70cm?
Jon...kf2e
Ordered.0
Yes it will0
Is this "ThumbDV AMBE3000" the proper device to order? One orders direct and not via FRS?
I ordered mine from Flex: http://cart.flexradio.com/ThumbDV_p_939.html1
Thanks Robbie, couldn't find that link. Much appreciated...
Tim
Howard, I was going to mention that and then thought, why bother.
Fantastic! Just ordered a ThumbDV!
Will that app be open sourced?0
It's been a while since I messed with D-Star. Is there D-Star activity on HF or is this for Flex radios with transverters?0
The way Steve explained it in an earlier post is that we will be able to manipulate the data in the "call sign fields" by means of an external program to SSDR. If this is true and according to some earlier posts this should allow operation on the D-Star repeater network (gateway system) To operate on the gateway system though you will need to register your callsign with your "home system" When this is done a unique ip address is linked to your callsign. This enables callsign routing and allows your data transmission out over the gateway system. For HF only none of that is necessary. I run a gateway system here in Nederland, TX (W5SSV) If i can help any one with general D-Star questions i would be glad to do so, however my experience with my 6700 is still a little limited :-) 0
International DSTAR HF Testing Net – SUMMER Schedule
Use your ICOM 9100/7100, or STAR Boarded non ICOM DSTAR HF, or the THUMBDV on a FLEX.
We routinely have two way communications coast to coast and North to South, South to Canada, Europe and Australia. We have had two way contacts to Japan. And have been heard in South Africa.
We are on each band only for 2-5 min. or so as to spend less time, if the band is dead we move on earlier. You can go back to a good freq after the net.
MONITOR REF030C to coordinate. WE may need to move early or if the freq is busy. We do not want to step on any AM or SSB activity.We also use a web page to keep track of who and where we are at - http://hf.dstar-relay.net/
You also can check-in to this web site anytime 24/7 to find a DSTAR HF Ham to talk to.
We will have a PRENET for 30 min. before the start of the scheduled time. This PRENET is for ‘FREE FORM” contacts. One should check the web site http://hf.dstar-relay.net/ sign in and find a working freq to work on. When the net starts at the scheduled time, please join the net and follow the freqs.
We have a post-net (Hot Wash) at the end, on REF030C and report on our 1 way and 2 way contacts. This is done by the QUICK KEY method.
DSTAR HF VOICE SCHEDULE (SUMMER)
Sat PM 7:00 E (2300Z)
Sunday AM 10:00 E (1400Z Sunday)(Spend more time on each open band, and start on 80m)Sunday PM 7:00 E (2300Z)
Tuesday and Thurs night at 8:30pm E (0030Z Wed and Fri)
Check USB/LSB on freq to make sure the freq is clear.
SUNDAY AM, we start with 80m and work towards 6 meters.
6 mtrs 51.180 DV for 2 mins
10 mtrs 29.480 DV for 2-5 mins
12 mtrs 24.938 DV for 2-5 mins
15 mtrs 21.380 DV for 2-5 mins
17 mtrs 18.148 DV for 2-5 mins
20 mtrs 14.325 DV for 2- 5 mins
40 mtrs 7.285(or another open freq) DV for 2- 5 mins75 mtrs 3.880 DV for 5 mins Backup is around 3.725.
NCS will check the freq ahead of time to make sure we don’t step on anyone 3KC up and DOWN.
See how to do DSTAR HF with an ICOM at- http://www.youtube.com/watch?v=oGF-qkdoid4
"Digital voice is defined in the Commission’s rules as voice (i.e. phone), not data, per Section 97.3(c)(5) of the Rules." Check out the most recent comments by the ARRL: http://apps.fcc.gov/ecfs/document/view?id=7521063715
Kent
KQ4KK
Sorry to ask what must be a **** question but... will the USB D-Star dongle plug into the USB port on the RADIO or into the USB port on the HOST?
Peter
K1PGV
Radio0
- 245 Community Topics
- 490 The Flea Market
- 7.4K Software
- 327 SmartSDR for Mac
- 243 SmartSDR for iOS
- 224 SmartSDR CAT
- 163 DAX
- 347 SmartSDR API
- 8.5K Radios and Accessories
- 769 Maestro
- 42 FlexControl
- 728 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 811 Third-Party Software
