The beat goes on ...
Gary,
I'm running the same XV144, also XV432 along with a KPA500 (Elecraft HF amp). I run these through a sequencer, in my case a DEMI (Down East Microwave, Inc). So if you decide to expand to more transverters or HF amp, you might think about this approach.
http://www.downeastmicrowave.com
Tom W4TMW0 -
Tom I know of a few that use them, really slick. They seem to work well.0
Followed your link to DEMI (Use their 2M amp on 6700) and I now know the cost of a sequencer. Can you expand on how to use on a Flex, especially without any band info coming from the Flex?
Kept looking and came up with the manual at http://01895fa.netsolhost.com/PDF/Manuals/TRS.pdf
Hello Stan,
My 6300 PTT line connects to the sequencer to key the HF amp and the VHF XVTR PTT line connects to another port of the sequencer to key my VHF amp. I can be more specific if you want.
Tom0 -
Thanks Tom,
I thought the sequencer's purpose was to permit keying either the HF amp OR the 2M amp (on the XVTR port) . Oh, you have a 6300. It seems the sequencer is equivalent to the TR ports on the 6500/6700 where both the HF amp and XVTR amp are still both always keyed.
The problem remains how to key either but not both amps. Specifically, in my case, how to not key the 2M amp while on HF.
Stan
Stan,
I don't own either the 6500 or 6700 but would find it strange they would be different from the 6300 in that respect. Maybe someone else can clarify.
Tom0 -
With a USB-8 relay card and DDUtil You can have 8 diiferent PA's / XVTR's controlled with just one PTT line from the FLEX. If necesary You can easy control 16 devices with DDUtil and the LPT port.
- 245 Community Topics
- 488 The Flea Market
- 7.3K Software
- 327 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 221 Shack Infrastructure
- 149 Networking
- 369 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
