SmartSDR V 1.3.8, last profile used does not load
DV
After using my Flex 6700 with Ver 1.3.8 software and properly turning it off, upon cold start of the unit, the name of the last used profile usually does not show up in the profile text box as being loaded. This box is empty, requiring that I load in a profile before using the Flex transceiver. Anyone else having this problem of a missing profile load on startup? Is there a cure?
I have had a blank profile once. I don't know how it became blank since there is not a blank choice in the profile pull down.
After selecting a custom profile and properly exiting through the file pull down all seems okay.
Hi Doug and Bill, I do on occasion get a blank or grey window when I start SmartSDR from a cold start of SmartSDR app. In fact if I try to call up a profile it will not open the profile selection window. what I have to do to make it work, is , **** the SmartSDR app and restart the app then select a profile, it works on this second attempt. On other occasions, when starting cold. I will get a random setup in SmartSDR and not the last setup. I only operate these days from the profiles, so why does it not remember the last setup? Other things that happen on occasion are that when I select a profile, SmartSDR will crash. After the crash and restart, then it will stabilize. I know now that the profiles are actually stored in the radio and not in SmartSDR. So what is causing this. Is there conflict between the Radio SW and SmartSDR? Who's the boss situation? Your guess is as good as mine.
I also get a blank window. The profile is listed, but does not appear upon cold start of my 6500. I muust select one before operating. This happens almost every time.
I too have to select my desired profile on my 6500, if not every startup, then at least most of them. I am guilty of just Xing out of the program rather than using the File menu... wonder if that will make a difference.0
Would be interesting Mark if you could try File vs X coming out of program.
I have another program (X-plane Flight Sim) that will do just that, X out and your last profile is not saved.
No 6500 here yet (on the way) but would be interested in your results.
Chuck
Same here. Obvious bug. Has anyone submitted an official bug report on that one?0
If you are using a router/switch between your flex and computer . This may have been affected by the Microsoft updates .
Since these updates my 6500 has been seeing this situation.
I reset the power on the router/switch and all works?? It's possible that Flex does not have the
"BUG"
Don't know when those updates were, but my 6500 has acted this way right out of the box. Also, I have tried shutting down with both ways, and no difference. BTW, what is the correct way to boot up or shut down the 6000 series radios? Didn't see it adr anywhere in the manual. I was told by a very good source it didn't make any difference.
Write a reply0
6300 here and none of the profiles I have saved show up later after closing the soiftware. It has been a waste of time to bother with profiles here. FWIW, this is Windows 7 64bit.0
- 246 Community Topics
- 488 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 163 DAX
- 348 SmartSDR API
- 8.6K Radios and Accessories
- 766 Maestro
- 41 FlexControl
- 733 Genius Products
- 255 Tuner Genius XL
- 85 Antenna Genius
- 229 Shack Infrastructure
- 153 Networking
- 120 Contesting
- 115 Amateur Radio Interests
- 813 Third-Party Software
