Monitor Gain
Terry K8EET
Once I have my 6500 audio set to the point that it sounds good (on air reports) I can no longer hear myself in my headset. If I increase the TX audio to where I can hear myself, my TX audio is sounding very or at least quite distorted. I can hear the distortion in my headset as well. Yes, I do have my headset gain wide open.
I'm not sure what you mean by TX Audio, but I agree that the Monitor gain is not sufficient. With headphones plugged into the radio front panel jack, the sidetone in the headphones is not enough to be as effective as I would like it to be.0
TX Audio . Transmitted audio signal.0
What about the MON slider?0
I don't think they can make it any longer.0
We must be on different planets. There's no such control as "TX Audio". There is a control labeled "MON" and you say "I don't thing they can make it any longer". Earth to Terry. Can you copy?0
My reference to TX Audio was the transmitted audio as received by the receiving station. I am using the balanced line input with a mic pre-amp. When I reduce the mic gain on the pre-amp to the level that will not over-drive the flex which causes distortion in the transmitted audio ie. TX Audio. With the monitor button activate and sliding the slider all the way to the right, I cannot get enough audio from the monitor to hear my voice. Thus my weak attempt to make humor about making the monitor slider longer. I realize it's not necessary for one to hear their own voice, but as an old broadcaster I prefer to do so.
Got it...On SSDR, the MIC level plus the MON level both control the monitor volume. So try reducing that preamp gain and increasing the MIC level to compensate. That should bring up the monitor level.
731 -
Thanks Steve,
I knew there must be a simple solution. I guess I thought there wouldn't be any amplification within the Flex. (And I didn't want to come on this forum and ask any dumb questions!)0 -
The purpose of this forum is to share knowledge. There is no such thing as a dumb question2
I have entered this problem report into our bug tracker for additional investigation. Thank you for the defect report.
Thanks Tim. I'll try the preamp-down, mic-level-up approach. Ain't it great how we identify problems, find solutions, and make the radios better every day?0
This is not a really a bad problem once you get things set up properly. The monitor could use a little more gain. I really **** my audio up, trying to make that mic that comes with the flex sound better, but a couple of flex users got me on the right path...or a better path. I don't think Flex is doing new Flex users any favors by sending that mic with the rig (hi)
I agree Terry. I'm surprised someone hasn't mentioned the monitor gain being a function of mic gain before. It's unusual.0
I tell my classes that the only dumb question is the one not asked (or just answered).
73, Bill, N5TU
Hope this helps as my 6500 does not produce this problem
My BAL control is below 50 .
My audio drive out of the electronic processing has been adjusted not to exceed 0DB (Into The BAL input)
The monitor slider for me to monitor ends up no higher than 70 to 80 on that slider.
Relating my settings may not help you Again there is no distortion listening to the headset and more than enough audio to consider what I am producing.
What I do is not use this ( mon ) to evaluate my audio.
1. Reduce power to Zero (0)
2. Press red button on recorder and transmit Press red button again
3. Press green button and listen to a very accurate (Thank You Flex) reproduction.
I am using Audio Technica cm50 headset .
Just as a question Listening to your radio with your headset my level is around 50% of that output slider . And under speaker this slider is 50 (Balance at center) Med agc and this is at 50 .
I wonder if this is simply a matter of headphone impedance? I'm using Sony Studio Monitor headphones, which are probably 8 or maybe even 4 ohm. I would imagine that a higher impedance headphone might produce a louder sound.0
Yep0
- 245 Community Topics
- 488 The Flea Market
- 7.3K Software
- 327 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 221 Shack Infrastructure
- 149 Networking
- 369 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
