6300 after windows 8.1 upgrade SDR keeps losing conection
Are you connected to the radio directly or through a switch or router?
Jon...kf2e
Try a complete uninstall of SmartSDR. This would include all previous versions, the CAT driver (FlexVSP in the Windows Control Panel) and the DAX drivers (uninstalled when you select NO during a SmartSDR uninstall. Then make sure you have all of the windows updates installed for Win8.1 before installing SmartSDR v1.3.8.
If that does not work, then submit a HelpDesk support ticket.1 -
Steve, you might check your ethernet adapter settings; one win 7 update here hosed up mine, FWIW.
per: http://helpdesk.flexradio.com/hc/en-us/articles/202118518-Optimizing-Ethernet-Adapter-Settings-for-M...
73, w5xz, dan
Just checking that you have done ALL of the additional updates after the upgrade to 8.1, there are many including specific driver updates for many Ethernet and video cards. You may need to check the "optional" upgrades listed when you force a Windows Update scan.0
Thanks all!
1: I am using a hub - I don't see (think) that a Switch or Router would be necessary keeping in mind the Hub I have been using has been working fine since May and there have been no changes in the LAN.
2: I did indeed remove all previous Smart SDR and CAT versions before reinstalling V1.3.8xx
3: I am not sure if all drivers were updated. Likely meaning NO. No I did not do any additional steps, nor did I note any messages that additional steps were necessary, I assumed (mistake, I know) that once WIN 8.1 loaded, updates would have or were done automatically. I will check on them when I get home tonight.
As an aside, I have to say that WIN 8.1 is an improvement at least at the GUI level over that of WIN 8.
I will keep all updated...
Flex 6300 with Windows 8.1 on a new Dell i7 machine. Only issue I have noticed is the Radio Settings have changed from my selected values (once). Tune power was set to some odd value which leads me to believe it might have been corrupted. DAX works perfectly well, and as an old UNIX and OSX user I must say that I am rather pleased with Windows 8.1 and the clean look of SmartSDR.
dan W7NGA
San Juan Island, Wa.0 -
Steve,
Whether it was working before or not you really should get a switch to replace the hub. Every hub I have ever seen is only 10mb and every switch is at least 100mb and many 1gb. I recently bought a 5 port gigabit switch for $20. It's too cheap an option not to get. Maybe it won't solve your problem but it will certainly enhance the performance of SSDR.
Jon...kf2e1 -
Still disconnecting after 15-30 seconds!
To be clear the message I get is:
"Connection to radio has be lost, please reconnect"
So far:
I have installed all of the available windows 8.1 updates, uninstalled Smart SDR and every bit of past Flex software, uninstalled anything I could find related to power and smart SDR. Reloaded everything from scratch. I have even gone into the device manager and checked that all devices where using the latest drivers.
Hub vs. Switch, I can see the point of changing out the hub, however I am reluctant to make any hardware changes and add yet another issue. The system was working at an acceptable level until I went from Windows 8 to Win 8.1!
Is there a hard reset for the 6300 and I and start the system as new?
On the 6500 if you hold the OK button while starting the radio after about five seconds you will reset the radio. I assume it is the same on the 6300. I don't think this will solve your problem because it only resets the persistence database and that is not likely your problem.
Why not hook the radio directly to the computer bypassing the hub and see if that works. A direct connection will rule out the hub.
Jon...kf2e
Found it! I poked around on the Board and found that Robbie - KI4TTZ (and others) were having the same issues. Looked at what folks were saying there and got some ideas! Turned out to be the CPU hitting 100% Cleaned up some stuff running in the background. the big offender was "Daemon Process(1015)" Looked around on the internet, I cant find anything definitive on this.. Any thoughts?? Looks like something the got switched on/installed with windows 8.1
27 years ago I started playing with Packet, we used to call this "pealing the onion" Thanks to all in the FlexRadio Community!
Now that I found the issue, I'll look at changing out the Hub.. Thanks for setting me straight!0
- 245 Community Topics
- 488 The Flea Market
- 7.3K Software
- 327 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 221 Shack Infrastructure
- 149 Networking
- 369 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
