Unhandled timer exception error in SSDR v1.3
Steve N4LQ
Used the 6300 all day yesterda. Got up this morning and got this Unhandled Error popup. I can hear the radio working and can tune with the FlexControl----Just no display. Rebooted PC and rig. Tried a quick reinstall of Ssdr without first removing the program and got the same error. Any suggestions? Steve N4LQ
2
We are aware of this error and have previously entered it into our bug tracker as a defect. It is currently being investigated. Thanks for the report.0
What's the procedure to recover? I tried a system restore to 8/21. No help. It pops up instantly when connecting to the radio. Should I reset the 6300? Remove SmartSDR?
Glad I have a backup rig.0 -
We don't have one yet. We are working on it.0
I happened to have a laptop which has 1.3 installed on it so I disconnected my direct connection to the main PC and connected directly to the laptop. No error but I could see the control panels only, no scope or waterfall.
I then did a "factory reset" on the 6300 by holding down the power button for 5 seconds as I applied DC. Everything came back to normal on the laptop as it would with a new installation and works.
So then I plugged the 6300 back into the desktop and attempted to run it. Immediately the ERROR pops up. So I plugged it back into the laptop and got controls only, no pan scope display and now no audio or control ability.
So I did another factory reset and now it's back up on the laptop.
I guess I'm dead on the main computer now. Something is corrupted. To the best of my knowledge the only change I did yesterday was to the Mic.bias for a new microphone.
So my question is this....If this is a "Bug" and someone is working on it, do we wait several months for a new software version before we can use these rigs or is someone going to email us with a cure. I'm just trying to make plans here.
Steve0 -
Steve please do this. Navigate to the %APPDATA%
oamingFlexRadio Systems folder. Copy the file SSDR.settings to a different location, then start SmartSDR. If this fixes your issue, I need a copy of the SSDR.settings file to do forensics on it.0 -
Where is the folder? I can't find it. Also note that I have uninstalled 1.3 and cat then reinstalled but no change.0
In the Windows search bar, enter %APPDATA% and click on the folders in the path.0
Found it. Your path doesn't work though. Those % signs aren't recognized. Searching on the file name works though. I moved the file and now it runs again at least for a while.
I'm searching for a way to attach the file.
<?xml version="1.0" encoding="utf-8"?><Settings>
<ApplicationVersion>1.3.0.116</ApplicationVersion>
<LastButtonPressed>Knob</LastButtonPressed>
<ButtonMiddleFunction>Master AF</ButtonMiddleFunction>
<ButtonLeftFunction>RIT</ButtonLeftFunction>
<FocusHelperDelay>2</FocusHelperDelay>
<UpdateSettings>True</UpdateSettings>
<FlexControlEnabled>True</FlexControlEnabled>
<FocusHelperTarget>None</FocusHelperTarget>
<FavoriteMode0>USB</FavoriteMode0>
<FavoriteMode2>AM</FavoriteMode2>
<MainWindowPlacement><?xml version="1.0" encoding="utf-8"?><WINDOWPLACEMENT xmlns:xsd="http://www.w3.org/2001/XMLSchema"; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><length>44</length&g...;
<FocusHelperOtherWindowName>
</FocusHelperOtherWindowName>
<AutoShowTutorial>False</AutoShowTutorial>
<FavoriteMode1>CW</FavoriteMode1>
<PrimaryKnobFunction>Tune Slice</PrimaryKnobFunction>
<chkShowTXWindow>True</chkShowTXWindow>
<SetupWindowPlacement><?xml version="1.0" encoding="utf-8"?><WINDOWPLACEMENT xmlns:xsd="http://www.w3.org/2001/XMLSchema"; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><length>44</length&g...;
<FocusHelperN1MMPort>12060</FocusHelperN1MMPort>
<ButtonRightFunction>XIT</ButtonRightFunction>
</Settings>
Send it to my e-mail
Well you'll have to tell me what your email address is.0
my first name at flexradio.com0
Is this a problem with just the 6300 or also affecting the other models? If its just a 6300 issue it might sway my purchase decision towards the 6500.0
Steve Jones. I doubt if you will get an answer on that question from Flex. All I ended up doing is searching for a file named ssdr.settings and deleting it. That cured the error. The file gets remade the next time you close Smart SDR. It just contains your settings from the previous screen. Somehow it got corrupted.0
It is an equal opportunity defect, affecting all models. We are not sure what causes a value in the settings file to have an out of range value, but we are taking action to prevent it from crashing SmartSDR. If you have this issue, deleting the SSDR.settings file will allow the SmartSDR to start.0
Noted thanks.0
Thanks Tim1
This bug has been squashed and will be included in the next release of SmartSDR of Windows.0
We have added a fix to the next release of SmartSDR that will prevent this bug from crashing the radio.0
- 245 Community Topics
- 490 The Flea Market
- 7.4K Software
- 327 SmartSDR for Mac
- 243 SmartSDR for iOS
- 224 SmartSDR CAT
- 163 DAX
- 347 SmartSDR API
- 8.5K Radios and Accessories
- 766 Maestro
- 42 FlexControl
- 727 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
