line input quit working
W5UN_Dave
LINE input has stopped working on my 6700. The computer and Flex 6700 have been rebooted several times, to no avail. I use the line input from a second computer that is sending tones from MAP65.
Yesterday this was all working just fine, and I was actually transmitting the tone signal on 2 meters. Then when I tried it again today the audio level indicator showed signal, but it never showed up as transmitted output.
After a few tries, even the audio indicator stopped showing signal.
I am at a loss at this point. I checked the incoming line, audio is there, it is just not coming through the flex. I am trying to get this ready for when I receive my DEMI 2 meter amplifier. Line audio is connected through the rear XL jack. This has been checked too.
I've checked, and rechecked everything several times, so I am confident it is wired and selected correctly (yes, mode is DIGU).
Has anyone seen this problem? Is it possible the internal input at the XL jack is blown?
do you have dax on or off
it is OFF, but I've tried it both ways. The setup of everything is the same as it was when LINE input was working.
Dave,
If you have not already done so, you might try resetting the radio to factory defaults.
If line input still does not work then it may be time to open a helpdesk ticket.
Al, K0VM
Dave,
Al, K0VM
This problem "magically" fixed itself. After many reboots of radio and computer did not fix the problem, I walked into the room in the morning to find the radio and computer completely frozen and locked up. I did the required reboots, and immediately went to 2 meters to see if the LINE input was working. Surprisingly, IT WAS. There is a bug in there somewhere, and I expect to see it recur at some point. I am unable to do anything to make it fail again, so I cannot say how it happened the first time.
All I can contribute is that the LINE input quit working, even though the audio level indicator showed it was there. Then even the audio level indicator no longer showed input. At the same time that this problem was happening, keying the back panel PTT did not trigger TX1, TX2, or TX3 to activate. However These outputs did work when keying with breakin with cw or when using VOX with ssb.
Dave,
If( heaven forbid ) it should occur again, you might also try removing DC from the radio for a few minutes... Just a thought..
AL, K0VM
I wonder if there is a single cable that routes the back-panel connector group to a
connector on the the main circuit board.....
- 246 Community Topics
- 488 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 163 DAX
- 348 SmartSDR API
- 8.6K Radios and Accessories
- 766 Maestro
- 41 FlexControl
- 733 Genius Products
- 255 Tuner Genius XL
- 85 Antenna Genius
- 229 Shack Infrastructure
- 153 Networking
- 120 Contesting
- 115 Amateur Radio Interests
- 812 Third-Party Software
