What's the recommended software to use with my 6500 for PSK31/RTTY/CW?
Albert W Anderson Jr
I'm having problems with compatibility. Have not been able to have Tx function cause the transmitter to transmit but I do get receiving working OK. I note comment about drivers not available for HRD which would be the program of choice.
No problem with HRD, at least not the current paid version. Just create a PTT port in CAT and set DM780 to use that. Set the mode to DIGU, and select the DAX button for transmit and you should be good to go.1
I think the latest version of Fldigi has support for SSDR and seems to work well at my QTH...
- 245 Community Topics
- 490 The Flea Market
- 7.4K Software
- 327 SmartSDR for Mac
- 243 SmartSDR for iOS
- 224 SmartSDR CAT
- 163 DAX
- 347 SmartSDR API
- 8.5K Radios and Accessories
- 766 Maestro
- 42 FlexControl
- 727 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 809 Third-Party Software
