RIT/XIT on 20 Meters USB crashes SmartSDR in V. 1.1
While trying to work RI1ANU split on 20 SSB, (14.205 Mhz) I tried to do it "quick and dirty" by using the RIT/XIT.
First I used the Flex Control Knob AUX3 button to move the Transmit frequency up 5 KHz. Then I used AUX1 to take the receiver the same distance up the band, hoping to switch back and forth with the RIT on/off button and my mouse.
As the RIT reached Somewhere around 4440 Hz up the system crashed.
I repeated it several times, each time after a power down restart of the 6500.
Station Information:
FLEX-6500
I am using SmartSDR V. 1.1, CAT & DAX with N3FJP ACLog 4.6 on COM 8
Flex Control Knob on COM 79.
No other programs connected to the rig at the time.
I have not done a Factory Reset and tried it again.
Has anyone else experienced this?
I hope I have not missed a note in the release notes... if so, I can confirm that this really is an error!
Ken - NM9P
Further tests revealed that XIT is not a factor. Simply moving the RIT past +4400 or so crashed SmartSDR and required cycling the 6500 before it would reconnect. I will do a factory reset tonight and test again.
Ken - please let me know how your testing proceeds with a persistence DB reset.0
Ken,
I confirmed this bug with my 6700.
Rather than cycling the 6700 I just wait a minute or two and the radio usually shows back up in the radio browser.
Confirmed on my 6500, XIT no problem, RIT both + & - ~4400 crashes SmartSDR. Same as Ken, wait ~1 min or less and radio is available to reconnect.
I will try that tonight, also. As well as other bands, other slices & other panadapters.. I only tested it on 20 meters in pan 1, Slice A.
OK. I have added this to the developers bug tracker to fix for the next release. Thanks for the confirmation report, Dave!0
- 371 Community Topics
- 93 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 35 Aurora
- 246 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 996 Third-Party Software
