RIT/XIT on 20 Meters USB crashes SmartSDR in V. 1.1
While trying to work RI1ANU split on 20 SSB, (14.205 Mhz) I tried to do it "quick and dirty" by using the RIT/XIT.
First I used the Flex Control Knob AUX3 button to move the Transmit frequency up 5 KHz. Then I used AUX1 to take the receiver the same distance up the band, hoping to switch back and forth with the RIT on/off button and my mouse.
As the RIT reached Somewhere around 4440 Hz up the system crashed.
I repeated it several times, each time after a power down restart of the 6500.
Station Information:
FLEX-6500
I am using SmartSDR V. 1.1, CAT & DAX with N3FJP ACLog 4.6 on COM 8
Flex Control Knob on COM 79.
No other programs connected to the rig at the time.
I have not done a Factory Reset and tried it again.
Has anyone else experienced this?
I hope I have not missed a note in the release notes... if so, I can confirm that this really is an error!
Ken - NM9P
Further tests revealed that XIT is not a factor. Simply moving the RIT past +4400 or so crashed SmartSDR and required cycling the 6500 before it would reconnect. I will do a factory reset tonight and test again.
Ken - please let me know how your testing proceeds with a persistence DB reset.0
Ken,
I confirmed this bug with my 6700.
Rather than cycling the 6700 I just wait a minute or two and the radio usually shows back up in the radio browser.
Confirmed on my 6500, XIT no problem, RIT both + & - ~4400 crashes SmartSDR. Same as Ken, wait ~1 min or less and radio is available to reconnect.
I will try that tonight, also. As well as other bands, other slices & other panadapters.. I only tested it on 20 meters in pan 1, Slice A.
OK. I have added this to the developers bug tracker to fix for the next release. Thanks for the confirmation report, Dave!0
- 245 Community Topics
- 490 The Flea Market
- 7.4K Software
- 327 SmartSDR for Mac
- 243 SmartSDR for iOS
- 224 SmartSDR CAT
- 163 DAX
- 347 SmartSDR API
- 8.5K Radios and Accessories
- 769 Maestro
- 42 FlexControl
- 728 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 811 Third-Party Software
