Looking at the road map are memory channels addressed
Dale KB5VE
Frequency memories are not addressed per say. I know profiles are addressed and using Stu's iPad program allows frequency to be maintained. In his program you name the each profile and in the power sdr it loads as the frequency and you set up a profile for audio and the such in another place. Will smart sdr have the same ability to set a radio profile such as Ssb ESSB, Ssb dx and a group of memory frequencies which will use what ever radio profile is selected? I am not sure which way is the best,I ab M a creature of habit and have several frequencies I use for rag chew a lot and would like the memories to be separate from the radio profile. Some would just like it all to be in the profiles. What is the the think tanks idea on this? Also what would the others on the community like.
I am using the DXLab Suite and within Commander, the memory channels work Flawlessly along with the scan function. Not only that, but with Commander I can tune SSB in 10 hz steps
Craig
W4CCW
That is good but I would like to see it in the smart sdr. I have profiles in the iPad program.0
Also k9dur has a great memory program for the flex....but you are right, should be built in. Greg0
- 246 Community Topics
- 488 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 163 DAX
- 348 SmartSDR API
- 8.6K Radios and Accessories
- 765 Maestro
- 41 FlexControl
- 733 Genius Products
- 255 Tuner Genius XL
- 85 Antenna Genius
- 228 Shack Infrastructure
- 152 Networking
- 120 Contesting
- 115 Amateur Radio Interests
- 812 Third-Party Software
