2M APRS Detector DX Monitor
Mike-VA3MW
Monitoring APRS beacons is a good way to watch for VHF openings.
Spot 2 m openings with APRS. SliceAPRS listens to APRS through a FlexRadio capable of receiving your local APRS frequency, usually with the use of a transverter, or a FLEX-6700 (not tested), works out which stations you really heard directly, learns your normal range, and tells you when the band opens.
I have not added a transmit version of this (just yet), but it would be easy enough to do. SliceAPRS is a Client, so it will use a single Client slice while running. You can run it as an app and you can also look at the data via a Web Browser.
https://va3mw.github.io/SliceAPRS
73, Mike va3mw
