Zeus Link Flex Alpha Version 2.0.63
I have been seeing a lot of Youtube Video's done by Doug, KB2UKA regarding Zeus Link Flex for the Flexradio. I was wondering if any in the group have
been brave enough to try this with their flexradio versus using SmartSDR? I realize that the Zeus Link is only a Software program and I know
that it is not a firmware upgrade to the flexradio.
Mark Griffin, KB3Z
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsIt’s a fair question, and lots of people are curious about it after seeing Doug’s videos.
A couple of things worth knowing before you try it. The developers have said publicly that they reserve the right to block individual users from running the software, and that has already happened to some folks.
They’ve also mentioned that access may eventually require their approval.
When I tried it, the software required my QRZ login credentials before it would run.
Personally, I wasn’t comfortable handing those over to a third party, so I didn’t go further.
None of this is meant to steer anyone away.
It’s your radio and your call. I just think it’s good to go in with eyes open and read their terms first so you know what you’re agreeing to.
To ask for someone's login credentials to me is not proper. So is that to say Mike that because you work for Flexradio, that you might do something with their code that they don't want. One's credentials for different things are yours and yours alone. Thanks for sharing that with the group.
Mark KB3Z
These random flex users seem to like it. About the QRZ sign in, I do not know KB2UKA personally but from what I know I think he would have a lot more to loose than to gain from the misuse of someone's QRZ sign in. Plus I understand they are changing to a new sign in system. Something more generic. Hope that helps.
Description of QRZ and login use and the why they use it in these pages.
For the core ZeusSDR radio console, you can still use the software without logging in — but ZeusChat and some community features will be locked until you authenticate via QRZ.
If you only want to run the radio console in offline or private mode, you may be able to bypass the QRZ prompt, but the developers have not confirmed this in the current release.I don't know anything about the ZeusSDR Community or anything regarding this.
Mark KB3Z
For the Flexradio the developers have said publicly that they reserve the right to block individual users from running the software, and that has already happened to some folks.
If ZeusSDR does not have access to the internet and your qrz login, it will not let you do anything. No transmit or receive.
If you login and then disconnect from the internet, the program will function up to 24 hours and the features you mentioned will not work. If you do not reconnect to the internet after 24 hours, the program will cease to function.
To put it bluntly, the requirement to have internet access to use the program is a method of controlling your station by the authors if ZeusSDR. And they can shut you out of their program at any time.0 -
- 417 Community Topics
- 716 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 140 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
