SmartSDR v4.3.19 | SmartSDR v4.3.19 Release Notes
Has anyone experienced their 6400 not putting out RF other that from the ATU?
Thank you and 73,
Scott/AA4WF
Melted relay
-1 -
I would also suggest two things:
a) try connecting a dummy load and see if anything changes.
b) open a Help Desk ticket. The Flex staff can work through the various diagnostics and get you set up with a return for repair ticket if necessary.
To Don, VE7ATJ, I'll try the dummy load, but do not know what that will prove. And to Erica, K0DD, what makes you think that it's a melted relay, and which one, as the radio does put out RF when I engage the ATU?
HI Scott… attempting to transmit into a dummy load will (I hope) rule out any problems with the antenna, etc. If the radio outputs to the dummy load, then the problem is likely after the output jack.
If nothing shows with the dummy load attached, then it is likely an internal problem (or configuration issue) within the radio and the Flex Help Desk are very good at running through the various diagnostics.
Don, The radio has an output when the ATU is engaged and as of yesterday the CW key will generate an output, but Digital modes and SSB phone produces no output. But, now there is a new issue, I have no sound out. I'm very frustrated with the radio and the SmartSDR software. It seems like every other day, there is a different problem.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsThis sounds like an audio path issue.
Can you post a screen shot of you doing FT8. We want to see all of SmartSDR including the right side panel. It is likely a simple configuration issue.
Hmmm, if there's no output except when you engage the ATU, it might be that the 'bypass mode' in the ATU is not working.
I definitely think it's time to generate a Help Desk ticket and let the Flex staff give you a hand. I understand the frustration, but radios today, especially SDR's like the Flex, need a whole different set of diagnostic tools and there's only so much we here on a discussion forum can help you with.
Please reach out to Flex.
Are you testing SSB using the microphone on the radio or through the PC?
Mike - Are you saying that the audio path is different from when you are using the internal ATU or not?
I am very curious to learn how it can be an "audio issue" as the radio has power when going through the ATU. Seems to me that something happened with the relay … as the RF is transmitted when the TUNER is in circuit, but has no output when it is not.
I might learn something new regarding my 6400 and 6600M 😉
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsI went back and read your initial post 3 times. I interpreted that TUNE works but Audio RF generation does not.
Are you saying that the radio works fine with the ATU in bypass?
If that is the case, then you have a hardware issue. Please open a support ticket and it is likely the radio needs to come in for repair.
- 419 Community Topics
- 719 The Flea Market
- 229 SmartSDR+
- 213 SmartSDR for Maestro and M models
- 474 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 335 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
