Flex can't fix our 6600 radios anymore?
Hi,
I wanted to flag that Flex can't fix our 6600 radios anymore. I sent them 6600 radio that have some problems, and the
answer I got was:
"As previously noted, these radios are no longer in production, and the boards are unavailable. In particular, the FPGA board is not available, which means we’re unable to repair the radio at this time."
The last 6600M I bought from them about 3-4 years ago probably failed under the same declaration...
Has anyone else gotten this message from Flex?
Nirmod / 4X1BG
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    It's a parts supplier issue. When something is built with state of the art chipsets, they are soon displaced by the next state of the art components and become obsolete. Then existing supplies will eventually be exhausted. Same thing will probably happen to the 8000 series and the Aurora. When is unknown at this point.
    Kinda discouraging, but older radios are not immune, just slower to happen.
  • Erika - KØDD
    Erika - KØDD Member ✭✭✭
    edited October 30
    If your finals fail out of any of the older JA radios… Finals… Many of those radios take major modifications to get the rigs to even work again. I bought two brand NEW in the box IC-756 MkII's at the same time, (early 2000's) for my station, near the end of their lives. It was only months before the MKIII radios came out.
    I dropped a lot of coin on those two radios. It was right before the VHF contest… I unboxed the radios brought them up on 6meters and they oscillated horribly. BOTH RADIOS DOA out of the box. Put them on the big dummy load nothing was working. Got back in the truck and drove the zillion miles back to the store plopped the two rigs on the counter and said if these can be fixed I'll keep them. BUT… I had an open account at the store back then, and the boss walks in back and comes out with a two wheeler with a brand new JUST RELEASED IC7800 on the cart. OK a little more than I wanted to spend, but hey the latest and greatest. I get a call in a month, store couldn't figure out the radios so they shipped them to the manufacturer. UNREPAIRABLE. They never even tried 6 meters when they ran out of finals… You know the 2SC blah blah blah with ABCXYZ tagged after the numbers. OUT of production. New ones had completely different specs.
    OK in the meantime we're finding all sorts of issues with 7800 in design… The radios Panadaptor QRM'ed the signals themselves… The noise blankers distorted the signals horribly. In the meantime The IC756 MKIII came out mine was only for if the main rig failed. when I removed it from the box it was DOA… That was it…
    We aren't talking finals here, its the main processing system FPGA… How many of you are using 386 or 486 or 586 or 686 Intel processors, and listen to the hollering when windoz 11 wouldn't run on processors without the correct instruction sets. Wellllllll Looks like we have gotten to end of life on 6400/6600 radios. Glad my 6500 is of the series it is. At this point I'm still going to be upgrading when I can keep the SteppIR working on the tower… I'm sorry for those with currently broken radios. Maybe some wizz **** engineer will come up with a plug in card that repairs and improves the rig. (Unless the finals are dead too gaak!) DD
    We appreciate that this can be a problem for some. I can also say that the service team is doing all they can to make sure a repair is not impacted by a lack of parts even if they can't be ordered new.
    Sometimes, we get donor radios that can be harvested for the next person.
