Is N1MM's Piper TTS System the same as a DVK Voice Keyer to Flexradio DAX?
It seems for some reason that DAX in Version 4.3.16 will not allow you to use N1MM's Piper TTS and also your Microphone if you have DAX Enabled. When I have DAX Enabled when using Piper TTS I can hear the transmitted voice when Mon is Enabled. Yet, when I key my Headset Microphone it keys the transmitter but will not Transmit my voice with Output Power. This did work on the last version of DAX. But it seems that Flexradio changed something with the new Dax is 4.3.16. I like to use a mixture of not only Piper TTS but also my Headset Microphone Audio to transmit a signal over the air. From what I have read, it seems that Flexradio is interpreting N1MM's Piper TTS as a Digital Voice Keyer which require DAX to be enabled and also to allow the transmitted voice to be heard when the Mon is enabled. Am I correct in this assumption? And is Flexradio going to correct this with another DAX Update?
Mark KB3Z
  • Erik Carling EI4KF
    Maybe you missed this? Or maybe not, but check it just in case:https://helpdesk.flexradio.com/hc/en-us/articles/56307893056155-How-to-Set-PTT-Override
    What Erik said, but it helps if you post your N1MM Audio settings.
  • Mark Griffin
    Mark Griffin Member ✭✭✭
    Mike,
    Yes I did read about the PTT Override. But that does not solve the issue regarding that when I use Piper TTS I am unable to hear the voice when I use MON. Can I now use Piper TTS and use my Headset Microphone? Yes I can. But the real issue is not having MON to be able to hear the Piper TTS Voice. Flexradio Sustaining Engineering now has what they call SMART 13514. But they don't have any solutions as of today.
  • Mark Griffin
