SmartSDR v4.3.19 | SmartSDR v4.3.19 Release Notes
Issue accessing my Flex radios while using AetherSDR via WiFi while SmartSDR connects.
I have checked the Windows 11 firewall and application settings and AetherSDR has both the Private and Public access checked in the firewall. I do not see SmartSDR on the list of apps however. I have not made any changes to either the hardware or software (that I am aware of) it just suddenly stopped working.
Any advice or assistance would be appreciated. Thank in advance.
Serge
VA3SB
Hi Serge… so, if I read your note correctly, you are attempting to access your radio via a hotel-provided wi-fi connection and while you CAN connect via SmartSDR, you are not able to successfully do so using AetherSDR. On AetherSDR, you are seeing the name of the radio at the bottom of the screen, but you are not seeing the signals on the panadapter.
Is that correct?
If so, you may be seeing a difference in the way AetherSDR and SmartSDR operate under the hood, as it were. SmartSDR is specifically designed and built to be a very light client — specifically to handle situations such as you are attempting (public wi-fi with possibly limited bandwidth. (Sorry, I have no idea what an MTU is or what the values you mention mean, so my apologies if I'm not being much help.)
I don't know if the same can be said for AetherSDR. I understand from the developers that AetherSDR is a somewhat 'thicker' client — requiring much more processing power at the computer and possibly requiring more bandwidth/packet-flow than is available at the hotel. The best bet would be to contact the AetherSDR team either through their Git-Hub site or the Discord channel. I have found them very responsive at both.
Hi Don. Thank you for your response. While I am attempting to use a hotel or a conference centre WiFi access point at the moment, I ran into the same issue while I was using my home WiFi network. However, if I use a LAN connection there is no issue.
I will reach out to the AetherSDR team. The strange thing is that it worked fine while I was using AetherSDR version v26.9.5 previsously at home using my WiFi network.
Thanks again for your response.
Regards
Serge0 -
no worries, Serge… ya… based on your notes, I'm thinking something changed in the latest version of AetherSDR which requires slightly more bandwidth (or something like that) which the local wi-fi just can't manage. Especially since it works when you hook it up to the LAN.
As I say, the AetherSDR people are really good about responding — either to GitHub or Discord.
Just a note tho (for others as well) AetherSDR is open source and is being maintained by a number of developers. Sometimes getting bug fixes or a new release published takes a little time. Please be patient.
- 419 Community Topics
- 719 The Flea Market
- 229 SmartSDR+
- 213 SmartSDR for Maestro and M models
- 474 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 335 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
