4.2.2 FREEZING
I am having a problem with my 6400M which is running on v 4.2.2 and the program has started stalling in receive mode. the Panadapter and waterfall are both frozen when this happens. I am on a PC. Audio, both SSB and CW is not affected. I have not transmitted when this occurs The computer is also frozen. I have run a cold boot to no avail. My setup is the 6400M into an ALS 600 amp and AT2K Tuner. Thank u.
    Hi Bob
    Sorry you are having issues. The waterfall can stall when the data is not arriving fast enough.
    What sort of network are you using?
    WiFi?
    WiFi with a Mesh or Range extenders?
    This will help to figure it out.
  • Bob
    Bob Member ✭✭
    Hi Mike
    Thank u very much for the reply! My shack is on the 2nd floor and the wi-fi modem is downstairs. I have run about 30 feet of quality #6 Ethernet cable directly to a router in the shack that connects the PC and the radio. This stutter is a recent development. The wifi is not 5G which is coming soon.
    I am a bit confused. Is their any WiFi between the Radio and the Operator?
  • Bob
    Bob Member ✭✭
    I think I was the one who was confused until I took a good look at what I did. Sorry about that. I will try to clarify…. So I think the answer to your original query about wi-fi is no; the station is running off the LAN/Ethernet port from the modem which is directly connected to the router in the shack with the CAT6 wire.
    Ah, that is a bit more difficult. It can be the radio or the transport layer (network)
    You could have a bad cable (it happens) or a network switch that is substandard. There are a LOT of cheap 1G switches. You'll have to try changing things and see if the problem changes or goes away. If you happen to have a 100Mb switch, try that as a test.
