SSDR v 4.3.16 or N1MM Logger+ Update 1.0.11466 ?
I am uncertain which change resulted in this because both updates were done w/in an hour of each other, but the two softwares no longer jive together like they used to wrt RTTY. In the past, with N1MM running and controlling SSDR via Smart CAT and a RTTY contest loaded in N1MM , switching bands would bring up RTTY mode on SSDR on the new band OR if N1MM's general DX log was employed switching between cw mode and rtty mode would enable RTTY in SSDR , HOWEVER, in both instances SSDR now selects USB vice RTTY when RTTY is commanded by N1MM. RTTY can still be manually selected via SSDR after a band change in N1MM or a mode change in N1MM's general DX logger, however , things worked better before when a command issued by N1MM maintained RTTY in SSDR vice switching to USB mode. Again not a huge deal but not as good as before.
One final observation, when mode change was commanded from cw to RTTY via N1MM, N1MM still loaded it's digital interface window and 2tone engine so it knows RTTY mode was commanded. SSDR went from cw to USB and when I commanded N1MM to xmit my call the AFSK transmission occurred on USB. For whatever reason SSDR is either no longer acknowledging N1MM's command to switch to RTTY or N1MM is now commanding a switch to USB vice RTTY or some other IT wizardry .Above my pay grade.
rig 8600 / pc win11(latest update) / SSDR v4.3.16 / N1MM v1.0.11466
73 mike
  • km9r.mike
    km9r.mike Member ✭✭
    Latest N1MM update has cleaned up this issue perfectly.
    73 mike
