SmartSDR v4.3.19 | SmartSDR v4.3.19 Release Notes
WinKey bridge v1.1 – DXLog → SmartSDR for Mac: no more Esc after F4, no F1 length limit
Hi all,
I've released an update of the small Python bridge that lets DXLog (Windows, running in Parallels) send CW through SmartSDR for Mac. It emulates a WinKeyer over TCP and translates it into SmartSDR CAT commands (KY / RX;).
What's new in v1.1
- No more Esc after F4. The bridge releases TX with
RX;automatically when the Morse is finished. - F1 and long messages are no longer truncated. The whole text is sent to SmartSDR in a single
KY. - WinKeyer-like behaviour. Characters are echoed back to DXLog at Morse speed, and the "idle" status is returned when sending ends.
- Clear buffer works as expected. DXLog's clear buffer stops the echo and releases TX immediately.
- Command-line options (
--wpm,--margin, ports and hosts) instead of editing constants in the code. - Optional macOS LaunchAgent installer, so the bridge starts at login.
Setup in short
DXLog connects to the bridge on port 5010 (Mac IP). The bridge connects to SmartSDR's CAT port 9881. The --wpmvalue should match the CWX speed in SmartSDR, because the bridge uses it to estimate when the message ends and to release TX. If your real speed is a bit higher than --wpm, TX is simply released slightly later. If it is lower, the last letters may be cut, so set --wpm at or below your slowest speed... no, at or above it. The README has the details, including how to tune --margin.
Please note
- The bridge has no authentication. Anyone who can reach port 5010 can key your transmitter, so restrict the listening interface or firewall the port.
- Speed is set manually and isn't read back from SmartSDR.
- Tested on my own setup (DXLog + SmartSDR for Mac). Other setups may need adjustments, and feedback is welcome.
https://drive.google.com/file/d/1tdJ7L8MSqLsfRyMxwmaNeqsVVtK4j5IA/view?usp=share_link
73 de IU3BRO
- 419 Community Topics
- 719 The Flea Market
- 229 SmartSDR+
- 213 SmartSDR for Maestro and M models
- 474 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 335 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
