SmartSDR v4.3.19 | SmartSDR v4.3.19 Release Notes
Multiple Flex Radios on Same Network
I have a 6400 on one antenna and a half 6500 on another antenna both running on the same network. SmartSDR cannot see both of the radios. It only sees my 6500. I really need some help on this one.
Robin
W4IEN
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsMy first thought is that both radios are not on the same network (subnet). What is the IP address of each radio? You could have a bad network cable, so try swapping things and see what changes. And, I know you can't tell me the IP address if you can't see it. :)
Tell us more about your network. Are you using a WiFi mesh or range extender?
I have both of the radios in the same subnet. I am using a WiFi extender. I did not have the problem when one of the radios was directly connected to my router. I am guessing the extender may be the issue. I just wanted to know if there was something I was missing about a Flex.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsHi Robin? How do you know they are on the same subnet?
This is why the IP address is critical to know. Both radios broadcast on the network and it is clear that one of them is on the same network as your PC, but the other one isn't as it can't be heard.
As a test, can you cable both radios into the same router / network switch as the PC? You should then be able to see both radios.
And, range extenders are 'ok' for watching TV, etc. But, it takes a bit more setup when you are dealing with specialized devices like your radios. It isn't seriously complicated, but you can run into a few issues.
The reason I know they are on the same subnet is because I was in system support with IBM for almost 20 years. I know the network side but I was asking if there was any issues I needed to deal with using two Flex radios on the same subnet with different antennas.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsNo, not at all.
If you know the IP addresses, then you should be able to ping all the radios from the host PC.
Well I figured out what was going on, I had a bad ethernet switch. I changed the switch and now all is well. Thanks to everyone for trying to help out this very old dude.
Robin
W4IEN
Out of curiosity, what switch was replaced and what was the replacement?
I replaced a Netgear 6 port with a Netgear 8 port.
tnx.
- 419 Community Topics
- 719 The Flea Market
- 229 SmartSDR+
- 213 SmartSDR for Maestro and M models
- 474 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 335 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
