N1MM to FlexRadio DVK integration (and more)
Mike-VA3MW
edited October 15 in Third-Party Software
In a contest, every time you reach for the mouse to click something in SmartSDR, you lose rhythm and sometimes a QSO. SliceTrigger fixes that by putting radio and station controls on your N1MM Logger+ function keys.
It’s a small Windows app that sits next to N1MM and connects to your FlexRadio over the network. Assign an action to an N1MM function key, and pressing that key does the job instantly. No window switching, no mouse.
What one key press can do
Receive antennas: step the active slice through your receive antennas (ANT1 → RX_A → RX_B → back to ANT1) to compare a weak signal on the Beverage, then return to your main antenna.
Voice keyer: play any of the Flex’s 12 voice keyer (DVK) memories. ESC stops playback, the same key you already use in N1MM.
Radio commands: send any SmartSDR command to the active slice (noise blanker, filters, and so on).
Station hardware: switch KMtronic network relays, or send a web or network command to other gear such as antenna switches and amplifiers.
Why it fits contesting
Everything follows the slice you’re working on, so the keys always act on the right receiver.
Several actions can be chained on one key.
The window is tiny, with a green light that shows the radio is connected, so it can sit in a corner of your screen.
It updates itself from GitHub with one click.
Getting started
  • Download SliceTrigger.exe from https://va3mw.github.io/SliceTrigger/
  • run it,
  • choose Settings > Install.
  • Connect to your radio, add an action,
  • Use Copy N1MM macro and paste the line into N1MM’s function key editor.
It’s early and actively developed, so feedback is welcome. The voice keyer needs a radio and SmartSDR version that include the DVK.
73, Mike VA3MW
