FLEXITNODE - The solution to CG NAT (Starlink)
VK1HF
VK1HF Member ✭✭
I built this a little while back.. but have been a bit busy to announce it.
If you have Starlink at your remote site, you have CG NAT, if you have CG NAT you have headaches - FLEXITNODE solves those. flexitnode.com
Take a look at the 3 sites we used to build and test FLEXITNODE.
https://ikara.vk1hf.com FLEX8400 - Canberra, Australia.
OTAMA.vk1hf.com FLEX AURORA510 - Victoria, Australia
https://alamo.k5yzw.com - Graford, TX, USA. - K5YZW.
I was connecting to both IKARA and OTAMA last night. Zoom in - look down the bottom - you'll see that the right hand side is connected to IKARA - the left hand side is connected to OTAMA. Both Using FLEXITNODE's to solve the Starlink issue. I was TX CW from OTAMA and RX on IKARA - they are about 1000km apart. just experimenting with AetherSDR client - but a good test of both systems and flexitnode also - Very So2R.
IKARA - is just a cabinet in a field - works so well. https://ikara.vk1hf.com/gallery/
Feel free to ping me - email is best - ian.vk1hf@gmail.com
