Trying Slice Logger
I am trying to set up Slice Logger and experience a problem with connecting my 8600.
Radio chooser does not show any radios. Entry via IP address does work, but Telemetry does not show any parameters for the radio.
Ultimately I would like to replace HRD with Slice Logger as logging software and interface it with JTDX and JT Alert.
Possibly someone can provide a detailed setup instructions for it as it could be of interest to other OMs keen to use Slice Logger.
Tom
  • Mick  W8BE
    Mick W8BE Member ✭✭✭
    Tom,
    There is a detailed setup instructions in Slice Logger.
    You should see the radio on discover. If you don't then check your firewall to make sure SliceLogger has permission.
  • Mr Radio
    Mr Radio Member ✭✭✭
    Thanks for your reply OM Mick. Good to see detailed help files in Slice Logger. I am able to connect radio by entering IP address, radio chooser does not show any radios. Radio frequency and mode are displayed but no telemetry data. Any suggestions how to make it working?
    Tom
