Tailscale Remote Access - Maybe IPv6 too!
Mike-VA3MW
The AetherSDR Team has been hard at work asking Claude some really hard questions.
They came up with a way that 'should' work for FLEX-8000's and Aurora radios to get to a radio at the end of a CGNAT connection such as Starlink.
Jeremy and I tested this and it does work when going from AetherSDR to the remote radio. I was able to use his radio on his Starlink connection.
It is very very ingenious and thanks to the way FlexRadio designed the radio so others can experiment, they came up with this solution. This is one of Steve N5AC's ideas from a long time ago (the ability to leverage the hardware).
It 'might' even work with IPv6 but it really needs some testers to give it a drive.
Good luck!
p.s. Don't ask me any hard questions, I had the easy part in this test!
  • Andrew O'Brien
    Andrew O'Brien Member ✭✭✭
    Thanks Mike , this should be fun.
    Andy K3UK
  • Mike VE3CKO
    Mike VE3CKO Member ✭✭✭
    Thank you for posting this Michael, was just what the doctor ordered. The FlexiSDR client can now reliably connect via my ROGERS cell network,thru my Xplore CGNAT provider to 8600. The key of course was flex-tailnet-shim, I installed it with the Waveform (docker) and once that was done I figured out the rest in and built the code that configures the container. Once it was successfully connecting new issues had to be overcome, It took some doing but Remote Access with IP in now available with FlexiSDR.
  • VK1HF
    VK1HF Member ✭✭
    Super good! - @Mike-VA3MW what is the position from Flex HQ on allowing some kind of tailscale shim/client to run on MaestoC also.? that would be SUPER excellent for sure.
    We built the radio so that this sort of experimentation/ customization could happen.
    I have 'root' access to my Maestro and it didn't work perfectly when I used TailScale on it and it was going to take a while to figure it out. If it worked out of the box, I had a chance to press our CTO that we need to spend time on it, but now, it would take time away from other projects.
    If you need remote Maestro access with your radio as a road warrier the quickest solution (at least for me) was that I would leverage Internet connection sharing (built into Windows - you can google how to) which means you hardwire (lan cable) to your Laptop and then run TailScale on the Laptop and let it connect to the radio.
    It turns out to be a pretty slick solution as it bypasses any paywall and if you need to run logging, wsjt, etc, you've got the laptop right there. I did this for years when I was on the road a lot.
  • VK1HF
    VK1HF Member ✭✭
    @Mike-VA3MW as an idea - maybe ask the CTO if it's possible for a few trusted people (suggest the project leads for AestherSDR) to get root access to their Maestro so that can build the solution out to get tailscale running on Maestro. Have some way where you give access to people who are not going to be raising a bunch of support tickets. I'm thinking like 5 people max.
    It is more complicated than you think and for the moment, I can say that that is not something we will do. Maybe at some time in the future. There is always a concern that the security key required could get accidentally leaked out.
    And, with that, all these computer devices have to go through very stringent and vwery expensive security testing if we ship product into the EU and we don't want to compromise that. This is part of what goes on behind the covers that impact retail prices. It is something that I never thought of as a consumer.
    We keep a very close eye on the resources on the Maestro to make sure the user experience is seamless. We don't want anything slowing it down, and as they say, if it ain't broke, don't fix it. :)
    Sorry. I think you'll find a tiny man in the middle router will be the fastest and most reliable solution. Easily done on a PI as many of us did that long before SmartLink was available.
  • K6AKK_John
    K6AKK_John Member ✭
    I have been using Zerotier with a PI on the inside now for a few months to remotely access my 8400 and Aurora boxes that are hosted on a Starlink network. I tried Tailscale first but getting it to pass the right packets was much harder than Zerotier. Zerotier does layer2 natively. It took maybe 30 minutes to setup both Zerotier and to configure the PI and now everything (other than a remote Maestro) just works. A Maestro could be used with a remote router added to your Zerotier network but it would take a few steps everytime you moved to a different WiFi.
  • David Decoons, wo2x
    i’ve been using the following travel router configured with a VPN back to my home router when in hotels and hospitals using a captive portal for logon to their network.
    It also works behind CG-NAT for radio end. At Field Day last year I tested remote operators accessing one of the Flex radios over a CG-NAT cell carrier at Field Day site.
    It works very well with the Maestro.
    https://www.gl-inet.com/en-us/products/gl-mt3000?variant=45270848929975&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&utm_source=google&utm_medium=cpc&utm_campaign=23950732687&utm_term=&gad_source=1&gad_campaignid=23950741117&gbraid=0AAAAA9rKFBaoOGrN8RkmCT9p-BnTlpd39&gclid=CjwKCAjwuobXBhBXEiwAYUaIlcxaatmacmxBUGQ2FTC7hAdxf7cM7GKu71wR08Q4jerM7B2f6VLasRoCMigQAvD_BwE
