SmartSDR v4.3.19 | SmartSDR v4.3.19 Release Notes
Yet another VPN Radio Tunnel Broadcast Wedge 2.0 – see your radio in SmartSDR over your own VPN
First, the important part: SmartLink is the best way to operate your FlexRadio remotely. It is built in, it is supported, and it needs nothing extra. If SmartLink works for you, use it and skip this post.
This is for those who already run their own VPN between two locations and want SmartSDR to connect through it.
THE PROBLEM
A FlexRadio announces itself on its local network once a second, and that is how it shows up in the SmartSDR radio chooser. Those announcements do not pass through a VPN. So even when your VPN can reach the radio perfectly well, SmartSDR at the far end shows an empty list.
WHAT THIS DOES
Broadcast Wedge carries those announcements across the VPN. You run it in two places:
- Near the radio, on a PC or Raspberry Pi on the same network as the radio (the "RSC"). It listens for the radios.
- Near you, on your own PC or any PC on your network (the "USC"). It repeats what the first one hears.
SmartSDR then lists the radio and connects to it directly through your VPN, as if you were at home.
Some years ago I posted a Python script that did this for one radio with hand-edited settings. This is a complete rewrite:
- Windows: one .exe, no installer, no Python
- Finds every radio by itself; nothing to configure per radio
- Shows live status, since it passes along the radio's own announcements
- Several remote users can share one radio site, and one user can see several sites
- You choose which radios are offered to remote users
It does not create a VPN and it cannot fix one that is not working. If you cannot ping the radio across your VPN, this will not help.
RASPBERRY PI (TEST BUILD)
There is also a version for 64-bit Raspberry Pi OS, so you do not have to leave a Windows PC running at the radio site. It installs as a background service, starts by itself when the Pi boots, and is set up from a web page in your browser. It works together with the Windows version.
Please treat this one as a test build. It has not yet been run on actual Raspberry Pi hardware. If you try it, I would very much like to hear the result. Note that its web page has no password, so anyone on the same network can change its settings.
TESTED WITH TAILSCALE
I have tested the Windows version over a Tailscale network. On the USC, you enter the Tailscale IP address of the RSC PC.
This has not been fully tested. It may turn out that you do not need a full VPN for this to work, but I cannot promise that yet. If you try it with Tailscale or anything else, please report what you find.
DOWNLOAD AND SETUP
Windows program:
Raspberry Pi test build:
Step-by-step setup guide, written for those with no networking background:
The Windows program is not digitally signed, so Windows may warn you the first time you run it. The source code is in the same repository if you want to look at it or build it yourself.
NO WARRANTY – YOU ARE ON YOUR OWN
This is a personal project. It is not a FlexRadio product and it is not supported by FlexRadio.
Please do not open a HelpDesk ticket about it. It is provided as is, with no warranty of any kind, and you use it entirely at your own risk.
If you try it, please post how it goes in this thread, and mention which VPN you are using and whether you ran it on Windows or a Pi.
73, Mike VA3MW
- 419 Community Topics
- 719 The Flea Market
- 229 SmartSDR+
- 213 SmartSDR for Maestro and M models
- 474 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 335 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
